Question about Keurig Platinum B70 Coffee Maker
My Keurig Platinum feels warm to the touch on top. Is this normal?
Keurig Platinum B70 Coffee Maker not de-scaling properly?
Purge and blow out the lines. Debis is in tubes and ports.
Jan 12, 2012 | Keurig Platinum B70 Coffee Maker
Keurig Platinum 1.8 L. After been turned off for a few month the MENU button does not lit up and AUTO TURN OFF is on, so I can brew a thing, since the mashine turns off before the water warms up.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101;'';;'
Aug 12, 2011 | Keurig Platinum B70 Coffee Maker
The hot water will not come out. I checked the top tube where the water comes out and it is clear. I tried without using any coffee and it still will not come out. It makes a sound like it normally...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 07, 2011 | Keurig Platinum B70 Coffee Maker
Has become slow when it works. has now stopped working. tank full of water, motor humms as normal, no water/coffee is produced.
heatman101
Jul 09, 2011 | Keurig Platinum B70 Coffee Maker
My Keurig/ Platinum coffee maker/ purchased 10/09 is running very slowly when making a cup of coffee. I have vinegar cleaned it as frequently as suggested by the manual and twice in the last 2 weeks w/ 0...
Hello, W/D here.
A lot of people have luck with clearing the needles to improve their Keurig's operation. Here's how:
Take an ordinary paper clip, and make it into an "L" with about 1" on the short side. Use the short side to probe up into the puncture needles on the top side of the K-cup, and the dispensing side as well. Frequently, grounds escape the K-cups and get trapped in the needles.
Best regards, --W/D--
Please feel free to rate this solution. Thanks.
Feb 05, 2011 | Keurig Platinum B70 Coffee Maker
Keurig platinum brewer says "not ready"....will
Sorry to read about your problem, I hope this helps you out.
sounds like you have defective unit, and since keurig, does not make replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Dec 30, 2010 | Keurig Platinum B70 Coffee Maker
I have the Platinum Keurig, but it will not take in any water from the tank. I've tried to descale, but if it won't take the vinegar solution, what else can I do?
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Sep 12, 2010 | Keurig Platinum B70 Coffee Maker
Our Platinum Keurig will not pump water. The motor makes 3 kind of grinding noises and then silence. I have cleaned out the jet with a pin, so it is not that
there are two needels. one enter the top of the KCup and the other the bottom.
Aug 20, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Platinum is clogged
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Mar 18, 2010 | Keurig Platinum B70 Coffee Maker
My keurig platinum will not pump water through the system
Jan 09, 2010 | Keurig Platinum B70 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
22 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
