Question about Epson Stylus CX5000 InkJet Photo Printer
Replacing Inkjet on Epson CX5000
I have followed the directions, but the red light keeps flashing and the "on" light keeps flashing. The directions say not to turn the machine off if the red light is flashing. Is there another step I have missed? All of the inkjets appear full and I believe it was only the black that needed replacing.
  • lionpride71 Nov 20, 2007
    I have installed software and "new" ink cartridges and both the red ink light and the on light are flashing in a flash, flash, pause pattern. I have received one error message "PrintOMatic Lite XL error, error type=24". I have uninstalled software and reinstalled it, when alignment page was suppose to print nothing happened. I tried to delete print job and it froze. The ink moniter shows all ink cartriges grayed out with a 'x' symbol over the black. There is something going on with the paper feed as well, at start up and shut down. I am running on 98se. Epson Stylus CX5000 is not supported by the SSC utility.
    Genius:
  • 2,985 Answers
Put the carriage to change cartridges remove the black and reinsert. Then if still in trouble repeat for all other carts. Meanwhile download the Epson utility from www.ssclg.com This fix all sorts of Epson problems
Posted on Jul 16, 2007
SOURCE:
I changed the cartridges in my epson cx5500 but its still not working
Problem with the Epson Stylus CX5000 InkJet Photo Printer
i changed the cartridges in my epson cx5500 but its still not working
Hi Good day!! is there any error message? or Blinking orange/red in your printer? if no errors try to restart your printer spooler.
Follow this method:
1. Turn off your printer and then trun it back on see your printer status if it is online and ready.
2. Click "Start"
3. Click "Setting"
4. Click "Control Panel"
5. Choose "Performance and Maintenance"
6. Click "Administrative tools"
7. Click "Services" now you should be on Services box
8. in Services box find "Print Spooler" Click it and then click "stop" at the upper left of the box and then start it again.. hope it works now..
Oct 19, 2010 | Epson Stylus CX5000 InkJet Photo Printer
INK DOES NOT FLOW. HOW TO CLEAN INK AREA.
Here is a few steps to clean the print head of your printer.
1. Make sure the CX5000 Series all-in-one is turned on but not printing, and the ink cartridges are not low or expended.
2. Right-click the printer icon on your taskbar (in the lower right corner of your screen). Select Head Cleaning.
3. Click Start or Next.
Cleaning takes several seconds. The CX5000 Series runs a head cleaning cycle and the On light flashes.
Caution:
Never turn off the CX5000 Series while head cleaning is in progress. You may damage it.
4. When the On light stops flashing, make sure paper is loaded in the CX5000 Series, then do the following:
Windows:
Click Print Nozzle Check Pattern. Then click Print.
5. If there are no gaps or lines, click Finish.
If there are still gaps or lines, or the test patterns are faint, click Clean to clean the print head again.
If you don’t see any improvement after cleaning three times, refer to Problems and Solutions. You can also turn the printer off and wait overnight. This lets any dried ink soften. Then try cleaning the print head again.
Tip:
If you do not use your CX5000 Series often, it is a good idea to print a few pages at least once a month to maintain good print quality.
Cleaning the Print Head
Hope this initial / info idea helps.
Dec 10, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Cx5500 printer cant print
Unless you have an empty ink cartrige, I'm guessing the print head is worn/burned out. You can check with Epson, but you are probably better off just finding another suitable replacement. Check out this one if you lake the Epson... http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&oid=63075462
Jul 12, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Red lights flashing. I dont think the ink is out and i did try taking them out following the instructions and put the same ones back in but it still won't print and the light is still flashing, will it...
Printer wouldn't print if red light flashing. Check status monitor for detail? Are some ink not recognized? Do replacement procedure from status monitor on "How to...". Unplug all ink tank. Plug only one ink tank . See status monitor. Is ink tank recognized. repeat procedure, and add ink tank 1 by 1. How about status monitor then?
Jul 09, 2009 | Epson Stylus CX5000 InkJet Photo Printer
DOWN LOAD MY PRINTER
You can download the contents of the printer's CD from Epson's website at the following link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=72185&prodoid=63059191&infoType=Downloads&platform=All
May 15, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Help!!!
If you use Windows, go to (long URL follows)
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=72185&prodoid=63059191&infoType=Downloads&platform=Windows
Download the driver for your printer. Then access the control panel and add hardware. Tell the wizard you have the disc and direct it to the folder you put the Epson driver.
I hope this helps. By the way, make sure you don't have a bad or loose cable.
Aug 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
CX5000 can't connect to printer
My son came by and fixed the problem. Thanks, Terry Eden.
Feb 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Problem with Epson CX5000 Scanner Driver
Download in google for free registry repair for VISTA and repair ur registry and try to install again...
Still not working,Try to install driver's on another location
And rate me as FIXYA please
Dec 21, 2007 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
333 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
