Question about Stamina Products Elite Recumbent Bike
Stamina bike syas stop how to fix it - Stamina Products Elite Recumbent Bike
I have a Stamina 4700R magnetic resistance recumbant bike. I'm looking for a place or website to buy plastic caps for the feet, a manual, and possibly the Stamina In touch fitness monitor. Where can I...
This is the main SITE for your unit, yet it appears to be an older unit, you can browse thru and maybe you'll find something similar to what you have and use that manual instead of the one you have. It probably won't be very much different from yours. As for parts, there are links on the page to find what you need.
Hope this is of help, Please rate and comment, Thank You
Joe
Sep 01, 2011 | Stamina Products Cycling
Ok i got this exercise bike at a yard sale its the stamina R360's and I didn't notice it doesn't contain the petal straps for it i need them for pt at home, tkr so my foot doesn't slide off...
Fixya does not sell replacement pedal straps and would not know of sources.
For a manual, try Googling (stamina)(R360s)(manual) without parens.
Aug 10, 2017 | Cycling
Stamina 15-1306 is not recording time, miles, calories, etc. Brand new.
The magnet located inside the right lower cover, which is attached to sensor wire needs adjusted. Just move it a little closer to Large sprocket which turns with the chain. Worked for me.
May 01, 2011 | Stamina Products Elite Recumbent Bike
The "Touch Fitness Monitor" on
I unplug the meter, take battery out, blow air (vacuum). It start working for 2 days then go back to display STOP again .....Not reliable design!!!!
Apr 10, 2011 | Stamina Products Elite Recumbent Bike
I just tried my Stamina e-1000 eliptical for the first time. The electronic monitor comes on but doesn't do anything. It just reads zero. Any suggestion? Thank you.
Check the upper console to see if you have a loose connections and one of them is the speed sensor connection , if all connections are good then it looks like the sensor itself inside the main casing by the flywheel
May 16, 2010 | Stamina Products Stamina Pro 5300 Silent...
Stamina R360s UP/DOWN magnetic restistance buttons not working
mine did the same thing.. unhook the plugs that are under the seat running from the handles and touch a screwdriver to two of the prongs on either side of the plug and it will engage the button for you on which ever side you do it.. the up or down side
Apr 21, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need the wheel bearing assembly for a Stamina bike model 890.
If your mechanically incline, Pull out old wheel bearing, if still in half way good condition, take to bike/auto shop see if they can find suitable replacement or rebuild the bearing it self. make sure when putting back in to use very good grease. I have same problem, since I can't find parts, those would be the best possible solutions.
Mar 16, 2009 | Stamina Products Stamina Pro 5300 Silent...
I need a manual on my stamina r360 recumbent bike how to clear the settings on the in touch monitor
If this is the same Stamina R360 as I have, you just hold down the orange oval button (labeled: MODE) until you hear a beep. This resets the readings.
Feb 28, 2009 | Stamina Products Stamina Pro 5300 Silent...
Stamina Products Elite Recumbent Bike Logo
29 people viewed this question
Top Stamina Products Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
Are you a Stamina Products Exercise and Fitnes Expert? Answer questions, earn points and help others
