Question about ASUS P5GPL-X Motherboard
Bios problem When I turn on computer it shows me massige CPU fan error press F1 resolve
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Your CPU fan needs to be replaced. If you don't, it could burn out you CPU.
    Scholar:
  • 145 Answers
Your CPU fan is not working properly. It is either jammed by dirt or already burnt. An immediate replacement is the only and the best option. Additionally, clean the internal area of your CPU, i.e. motherboard, fans, heatsinks etc.Use anti electrostatic means while doing this. Use the good quality branded fan for the CPU.
Posted on Jan 26, 2009
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
When I start my computer, I'll get a black screen with a bunch of text with "American Megatrends" as the header. The screen is unusual, and on the bottom it says "CPU fan error!, press F1 to...
You need to plug in your CPU fan. The CPU fan is VERY important in that it constantly cools your processor, making sure your computer doesn't over heat. If the computer runs and the fan isn't running, the CPU will over heat and cost you hundreds of dollars.
Turn off the power Unplug your computer Open up the case of your computer Find your CPU fan Find the cord coming from it Find the plug on your motherboard labeled CPU fan Plug it in there Plug your computer back in Turn it on
Mar 17, 2011 | iBuyPower Gamer Extreme 573D3 Phenom II X4...
(1)cpu fan error (2)chassis intruded (3)fatal error.....system halted
The reason for this error is Overheat! Please replace the CPU Fan with a new one and add additional Fan for the CPU Cabinet in order to cool the CPU. Then, reset the BIOS to default value by pressing the F2 Key or Delete Key at the Startup and select Load Optmized Defaults or Load Fail Safe Defaults option. This should resolve the issue.
Mar 02, 2011 | Computers & Internet
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
I REPLACED MY MOTHER BOARD WITH ASUS P5PE-VM. WHEN TURNING ON THE UNIT, INTEL CPU CODE ERROR APPEARS.
It just means that the bios is older than the cpu so it can't identify it (read its ID code). It shouldn't be a problem and a bios update will fix it (eventually).
But then, your computer will running good even the error appears. just set ur bios and the disable the press F1 for the error..
Jan 28, 2010 | ASUS Computers & Internet
Fails to boot, fans and lights on, no bios or anything
My recommendations would be to remove all connections to the board.
Remove the CMOS battery.
Remove the CPU fan and CPU.
Look at the top of the CPU, if you have a crust over the top of the CPU, you will need to remove it to a clean surface.
Next, your CPU fan should be a 3 wire connection on the motherboard, within two inchs of the CPU holder.
After cleaning the CPU, re-inseart and apply a heat sink lub for good heat transfer.
Re-install CPU fan and plug in to board connection.
Re-install your CMOS battery and power up unit.
With the CMOS battery removed, the time and date will need to be reset.
Also, in the BIOS for that board, you should be able to see temps. and rpm readings. ??
Hope the CPU has not taken a dump on you.!
Before you plug in the drives and other devices, check temps. rpm and voltages.
Have fun, hope this has helped you.
Oct 06, 2009 | ASUS P5GD1-VM Motherboard
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
ASUS P5KPL-AM CPU fan connection.
You should still be able to connect the 3 pin connector of the fan to the 4 pin connector on the mobo, the keying tab is offset so that you cannot connect it to the wrong pins.
If you still don't want, or can't connect it there, simply go on the Bios (press delete after you turn on your computer) and you will find an option to monitor CPU fan speed.
If you need any more help, let me know
Alex
www.CAS411.com
Mar 28, 2009 | Computers & Internet
CMOS setting distrubed for mercury PVM7 ver 1 board
just press del to enter to the cmos and then change the date and time of cmos and press F10 to save your configeration if you start the cpu again and if you see the message "press F1 to continue and del to enter bios it time to replace your cmos battery inside of cpu is like a coin inside of your computer
Nov 24, 2008 | Abit AB9 Pro Motherboard
CPU fan not detected.....
The cpu fan has a three wire connector that connects to the mother board. Usually located to the right & up from the cpu. If yours is connected currently the wires may be miss aligned. From left to right the pins are: first pin ground/Black; middle pin 12v./Red & last pin rotation/Blue. There may be a bios update that address this issue. Dell does not give up information easly.
Jan 13, 2008 | Dell Dimension 2350 PC Desktop
ASUS P5GPL-X Motherboard Logo
118 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
