Question about Brother MFC9320CW All-In-One Printer
MFC-J4510DW shows idle and won't wake up
The MFC-J4510DW is connected wirelessly to a mac book pro however it wont wake uo when the print command is sent It just remains ready and idle . Any idea on how to wake this up?
I had the same problem
on my brother MFC-9320CW
I set it up to work over wifi and it worked well for months then i started having issues one day (showing offline)
i had to restart the printer all the time to be able to print again (showing as Online).
but after 10 - 15 mins it lost connection again and I could not see it on network (PING IP)
I couldn't even web-interface to the printer in the browser using its IP address (** see below)
It appeared to point at a printer problem
I know this may seem strange but eventually my investigation came to finding that it was a router problem - well my router anyway.
It doesn't make sense i know - but it was definitely a bizarre router problem in my case.
After that i was able to web-interface to the printer
I RECOMMEND YOU DO THIS:-
1. turn off your printer
2. restart your router
3. wait 2 mins
4 restart your printer
IF YOU FEEL CONFIDENT TO DO EXTRA TECHNICAL/NETWORK CHECKS
Also allows you to manage things at your machine
5. ** find out the IP address of the printer - either on the printer itself - menu>network>IP
ive setup my printer to be static IP so i always know what it is
OR If you know how to get into the control panel (web-interface) of your router then it will show active connections and IP addresses of equipment - including your brother printer
6. i use the web-interface as it immediately shows me if i have a dropped wifi problem--If the printers control panel is avalible in my browser then all is fine
Posted on Feb 27, 2014
lucky1484
  • 90 Answers
SOURCE: cant connect printer to wireless laptop.
have you setup the wireless connection in between the printer and the laptop...
your laptop is working wirelessly with the internet but for making the printer to use it wirelessly the printer should be also a wireless printer.
and if the printer is a wireless printer then you have to setup the connection in between the printer & laptop to work wirelessly.
Posted on Apr 25, 2009
BubbaGuru
  • 70 Answers
SOURCE: ! Unable to print 36
here is the solution according to brothers website
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000012648&Sympt=How+do+I+clear+error+message+Print+Unable+36%3f&Model=1208&ProductGroup=1&ProductID=HL4070CDW
Posted on Mar 23, 2009
SOURCE: MFC 440cn, lost mfl pro suite
The advice given so far is not entirely accurate.
On the Brother Wesbsite:
Select the downloads link.
When searching for your download
Step 1:
make sure you have "ALL" selected
Step 2 and 3 are self explanatory
Hit the search button and then you are looking for the download that says "full software and driver package".
Install as directed.
Posted on Dec 01, 2008
Patzky
  • 240 Answers
SOURCE: My MFC 685 CW will not print.
Hello ,
First, we will have to make sure the printer is properly connected to the network
  1. Go to your printer.
  2. Press “menu” and scroll down to network, then WLAN
  3. Go to TCP/IP
  4. Go to IP address. Make sure there is an IP address here (not 000.000.000.000). Change the last 3 digits to “050”
  5. Change the boot method to “static”
If your IP address is not a valid one (all zeroes) or is an APIPA address (starting with 169.254.#.#) you will need to run the wireless setup wizard again as the machine is not properly connected wireless
If you had a valid IP address before changing anything, it means that the printer offline is caused by the computer not being able to locate the printer.
This is usually caused by the printers IP address changing.
Changing the boot method to static will make sure the IP address on the printer does not change.
Now we will have to make sure the computer knows where to find the printer.
On your computer, go to your start menuè control panelè printer
Here you should see your brother printer. Right click on the printer and select “properties” (If you are running windows Vista, make sure select “run as administrator” and then properties)
Go to the “ports” tab
Select “add Port…” and then double click on “standard tcp/ip port”.
This will bring you to the add port wizard, click next.
In the field for “Printer name or IP address” enter in the new IP address of your printer and then press next and finally “finished”.
Make sure to apply the changes.
You should now be able to print.
Thank you,
Posted on Mar 29, 2010
  • 114 Answers
SOURCE: MFC-8870dw 30ppm Wireless Network Multifunction Laser Printer with Duplex Printing, Copying,...: How do I connect my Brother MFC-885CW printer to m...
Connect the printer with a USB cord to the computer. Switch off the printer and install the driver in to your computer , during installation the software will tell you to switch-on the . Do so and finish the installation .
This is the procedure to connect the printer with your computer.
Posted on Jul 21, 2010
How do i connect my printer to my mac book pro computer
Check that your printer has a Post-Script unit, necessary for Mac users. Otherwise you can just order it, not too cheap.
Oct 21, 2014 | Ricoh Aficio Office Equipment & Supplies
Wireless printing
you need to set the ip on the printer to within the ip range of your wireless router. Then you need to install a mac book pro driver for the canon i960 on the Mac Pro. THe mac pro should then automatically detect the printer and hook up to it
Apr 21, 2014 | Cannon Canon i960 Photo Printer
Scanning "check Connection"
Must be a software installation fault. De-install using the de-install utility in the CD that comes with the machine and reinstall.
Jan 20, 2013 | Brother International Brother MFC-J4510DW
MFC-J5910DW wont scan to macbook
Hi Russ unfortunately I cannot help with your query, but have a quick question.. I have a Mac Book Pro running 10.7.5 but cannot get the install cd rom to work, what drivers did you download for it? Many thanks and hope you sorted your issues out! Giles
Oct 11, 2012 | Brother International Inkjet Multifunction...
Bought a Samsung CLX-3185FW to be able to print wireless from my macbook pro with snow leopard OS X 10.6. Software seemed to load ok, but each time I try to print, the mac is saying the printer is of
it really works ! you just simply have to update the printer drivers ( if it is connected to network and supports wireless printing) . I have done so in my office and everything works just fine. i
Jan 21, 2012 | SAMSUNG CLX-3185FW COL LASER MFC Projector...
Printers driving me crazy; I have three HP printers and none will print for me now
To Add and set as Defult Printer Go to system Preferences>Print and Scan > "+" symbol on left corner and add the printer.
when you give a command of print there you can see the list of printers and you can select the printer you want to print from.
Oct 29, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I have a new MacBook Pro and cannot get my Brother printer to work with it. The computer recognizes the printer but does not print.
Did you install the Mac driver for MFC? The MFC comes with driver for windows and Mac. Place the Mac Driver disk to DVD slot and run the installation for your MFC printer. Follow the instruction to complete the installation.
When you try to print something, make sure the MFC printer is selected.
If you've done all of this and still not able to print, please turn off your MFC, wait 15 seconds and turn on again to see problem solve or not.
Hope this will help. Thanks for reading.
Jul 19, 2011 | Brother MFC 420CN All-In-One InkJet...
Brother MFC9320CW All-In-One Printer Logo
2,462 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
