Question about NexxTech 175W Power Inverter
Ruining lap tops
My wife just had two laptop computers ruined using the 175 w mobile power inverter. One of the computers was almost new , but bought at circuit city, and they are going out of business. My wife is desperate because she has all her college info on the laptops. Why did this happen?
175 W inverter is not enough power for your computer and most of the cheap inverters do not put out a true sine wave. Buy one rated at least at 400w. Then it will output continuously at 300w. That should be sufficient for your computer. Your 175 w inverter is overtaxed then the voltage drops increasing amperage and burning things out.
Posted on Jan 02, 2010
You are too stupid to plug the computer in to ta regular outlet.
Posted on Feb 09, 2009
How do I stop my tuch pad om my lap top jumping went powerd by inverter
Power is too noisy. Use the battery and switch the laptop off to charge the battery.
Oct 03, 2014 | HP Pavilion Computers & Internet
Why is my monitor only showing white?
Your LED Panel looks got damage, no need inverter to repair, just replace your LCD Panel
Aug 30, 2014 | DMCOM Viewsonic Vx2250wm-led 22-inch...
Jazzy Select controller on-off switch (push button) very difficult to operate. Must push button down with much force to get it to work. Can I get the controller apart without ruining it?
The display on top of that joystick controller is essentially a fancy decal. it can just be peeled off. Usually when the symptom you're describing is happening it is because the button on the underside of the decal is wearing out. This can't be fixed. The joystick face must be replaced. However, you should be able to get this from a certified Pride dealer for 60 or 70 bucks versus several hundred for a new joystick controller.
Mar 27, 2013 | Pride Mobility Jazzy Select Wheelchair -...
I dont knw why but my laptop heats up way too much and i knw there is some kinda system all laptops have which keeps your laptop cool, but it doesnt work with my laptop plus i dont hear the fan. can some...
Shut the lap top off completely do not use untill you replace the cooling fan. If you use it you will ruin it. You will have to have someone that knows what they are doing to replace this fan. For the sake of your sanity take it in and get a new fan installed now. John
Jan 26, 2011 | Computers & Internet
Can my toshiba laptop run on a 175watt power inverter in truck? the toshiba is satallite l305-s5974, and inverter is a roadpro 175watt/140watt constant with overload/overheat protection built in? the power...
you dont need to buy anything from radio shack, the inverter that you have will be just fine. i have used smaller and im sure cheaper inverters with no problem. i keep my company laptop constantly plugged in and charging all day everyday running service calls.
Dec 17, 2009 | Toshiba Satellite L305D-S5904 Laptop
Water was poured on the laptop
Ouch, you really should pull the battery and disassemble the laptop and dry the component ASAP. Water is really bad for your laptop. You didn't list the model, so can't help you with the disassembling instruction, but in general, the disassembling starts with the top.
Oct 04, 2009 | Acer Computers & Internet
Dim screen ruining my Hannspree
your LCD screen backlite bulbs are bad or the inverter card the drives them is going bad
Oct 02, 2009 | Computers & Internet
I HAVE USED THE NEXXTECH 175 WATT POWER INVERTER
have you charged it,and check if the battery is still ion good condition
Jul 25, 2009 | NexxTech 175W Power Inverter
Compatible laptop sceens
You won't know until you dismantle and remove both LCD screens.
They could have different video connector and power connector for the inverters.
The best bet is to buy a new LCD screen or if the LCD screen is OK but the backlight CCFL lamp is worn out or the inverter is faulty, then the CCFL lamp or inverter can be replaced fairly cheaply.
Check out LCD Parts for compoments, repair and DIY info. Use this link.
www.lcdparts.net
Jun 23, 2009 | Toshiba Satellite A135-S4527 Notebook
NexxTech 175W Power Inverter Logo
304 people viewed this question
Top NexxTech Electronics - Others Experts
Are you a NexxTech Electronics - Other Expert? Answer questions, earn points and help others
