Question about Inter-Tel Intertel 6123300 GLX Executive Phone
Ip phone - cannot find IP address
I am trying to get an Intertel IP phone to work with a Vodafone Netgear router. Our IT guys have said that it a router problem - I have been on the phone to Vodafone who have checked my settings and say that nothing is blocking it. The IP address in the computer is the same as the one I have programmed into the phone. Any ideas - please?
  • Anonymous Apr 23, 2009
    no clue and the phone doesn't seem to have any settings that are easily accessible.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
The phone and the computer can not be the same IP Address will not work..
Posted on May 19, 2009
My LG 55LW6500 55 3D HDTVReady LCD won't connect to my NETGEAR R6200 router. The gateway does not pass!
try to manually configure the ip address on your TV settings ... ip address , subnet mask, gateway and dns. refer to the ip address used by your router. :)
Aug 10, 2013 | NA Netgear R6200 802.11ac WiFi Dual...
Netgear router try to connect but saying validating identity wat can i do
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | NetGear RangeMax WPN824 Router
I cant seem to get the right ip address
If you are looking for your own ip address try using www.ipchicken.com This website displays your current ip address
Feb 28, 2011 | NetGear WGR614 Wireless Router
Am not able to access my router using IE 8
goto tools > internet options > advanced > restore ie settings..... restore the settings and type the ip address of netgear in address bar of ie8....
you can also use ctrl+o and type the ip address in box and click ok...
it will open..... if it is not opening still then check for the ip address in your computer.... it should be in the range of netgear router.... if you are getting valid ip, then try to ping your default gateway address of netgear router.... pls comment me if you have any doubts... i will assist you further....
May 08, 2010 | NetGear WGR614 Wireless Router
I have Netgear N router and having problems trying to establish phone connection with my Mitel 5312 ip phone. I have fowarded all the ports, disabled router firewall powercycle everthing a thousand times...
The phone is intended to be connected to a Mitel PBX telephone system. If you're using the phone at home, you must set the phone in Teleworker mode and use the IP address of the teleworker server. This will allow your phone to tunnel into the phone system.
OR the phone must be set up in SIP mode. Press and hold the 6 key while booting the phone. You will also need to set it up and tell it where the SIP server is located (IP addresses).
If you don't have this information, you should contact your vendor or system admin for further assistance.
If you are trying to use the phone without the above servers, I have bad news - it won't work.
Apr 07, 2010 | NetGear MR314 802.11b
CANT RUN XBOX LIVE AND MY PC HAVE NETGEAR ROUTER
Open port numbers UDP 88 and TCP 3074 pointing to the IP address of the XBOX. Make sure that the IP address of the XBOX is within the IP segment of the router. Ex. if your router has 192.168.1.1 IP address your XBOX should have 192.168.1.x IP address.
Feb 22, 2010 | NetGear RP614 Router
Where is the ip adress
If you want your WAN IP address(Internet IP):
www.ipchicken.com
If you want your LAN IP address:
Go to Start then Run
Type in ipconfig
There is your LAN IP, usually starts with 192.168.x.x
Oct 06, 2009 | NetGear RangeMax WPN824 Router
Applying QoS to WNDR3300
You may stop what you are doing right now. Nothing you do will work regarding QOS and your Avaya IP phone?
Is this a hardware VPN, or a VPN remote phone? (vpn client on the phone)
Depending on what system you are connected to, an IP Office or a communication manager, there might be settings to do, but none of them are qos.
QOS is inserted on the LAN, once the packets leave the LAN and hit the open internet, there is no QOS.
You might be able to change the compression algorithm the phone is using, which might help.
Jul 30, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
VPN passthrough
What are the settings that you have for your netgear router? Its going to tunnel, right? Try this solutions and see it will work.
1. Access the set-up page of the router, from a browser, type 192.168.1.1
2. Go to VPN tab and select IP SEC VPN
3. Local Security Group, set it to subnet and input the Network Address of the router (LAN IP - 192.168.1.0)
4. Remote Security Group, set it to subnet and input the Network Address of the netgear router (LAN IP, for example - 192.168.2.0)
5. Remote Secure Group, set it to IP only, WAN IP address of the netgear router
6. For Key Managemnt, just make sure that all settings are identical with the netgear router
7. Last go to Advanced Settings and make sure that group settings are identical to the netgear router
Hope it works for you
Jun 24, 2008 | Linksys RVS4000 Router
Inter-Tel Intertel 6123300 GLX Executive Phone Logo
384 people viewed this question
Top Inter-Tel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
