Question about Novelty 96512 Cuckoo Phone
CUCKOO TIME ADJUSTMENT
HOW DO U ADJUST THE TIME TO GO FORWARD OR BACK ON A BLACK FORREST CUCKOO.I DONT SEE A ADJUSTMENT ON THE PENDILLUM
  • 714 Answers
Http://antiqueclock.clockstop.com/CUCKOO.htm
1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
Hope this tip helps.
R/
David
Posted on Feb 04, 2010
My cuckoo clock chimes hour chime on hour and half hour. For instance, if it chime 4 times at 4 o'clock,, it will chime 5 times at 4:30. Any help appreciated
It probably just needs cleaned and adjusted. You can look up clock repair shops on the internet or in your phone book. Since the clock is smaller, it can be taken to the shop cheaper than having someone come to your home.
Feb 19, 2017 | Chime Home
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
Do cuckoo clocks need to be certified to be real?
There is a Black Forest Clock Association. They certify cuckoo clocks that are made from wood and made with parts produced in the Black Forest region and that meet the standards set by the association.
Feb 11, 2013 | Home
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Sep 08, 2011 | Casio Gshock G Shock Analog Digital New...
My S018 aurora is un-controllable, can barely mantain stability, All we can do is hover, have adjusted trim and spent hours trying to gain control. Frustrated, is there an adjustent screw on the aircraft...
If you mean it is spinning then: Adjust the trim so that you can hover and maintain stability at ALL altitudes and climb rates then i think you mean that once you push some forward on it will now spin. DONT WORRY or HOLD BACK. The craft will now spin but hopefully it will stop and begin moving forward you can now adjust its spin by using the right control stick (or a little trim). After practice it should beome easy.
Also Drafts can effect the craft quite violently so check your area for open doors etc...
hope this helps
Dec 26, 2010 | Toys
Reverse doesn't work
You need to adjust the linkage so that it goes forward only when it is in FORWARD then reverse will work
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I change the time on my tissot touch watch
you can adjust the time by rotating the nobe at the back side of your clock,if it is a digital clock it has a button to adjust time ,press the button and see current time and adjust it
Apr 01, 2009 | Watches
TIME ADTMENT ON MY BLACK FORREST CUCKOO CLOCK
Are you trying to get it in time say to run faster or slower? If so the leaf should just slid up to speed it up or down to slow it down as it is only a friction fit. Hope this helps
Jan 26, 2009 | Novelty 96512 Cuckoo Phone
Had a new battery fitted to my tag 6000 and now 2 of the dials dont reset to zero
To reset the chronograph dials back to zero do the following:
1) Pull the crown out to the position where the date can be adjusted and push the buttons.
2) Pull the crown out to the position where the time can be adjusted and push the buttons.
Jan 06, 2009 | Tag Heuer 6000 WH1312.BA0677 Wrist Watch
Novelty 96512 Cuckoo Phone Logo
274 people viewed this question
Top Novelty Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Novelty Lands Phone Expert? Answer questions, earn points and help others
