Question about 2001 DEVILLE A/C Compressor a1z29394 8-279, 4.6L
Engine service code B O 423 cadillac deville 4.6
What is this code
  • 139 Answers
SOURCE: 2003 Cadillac Deville a check gas cap error appears with svc engi
put a new gas cap, those system are pres. even if
the cap look ok it maby leaking replace with a new
one it should solve your prob.
eng.ligh come on because of the gas cap
Posted on Apr 09, 2009
  • 7 Answers
SOURCE: Cadillac Deville 2000- Engine check light code P0741
If you like go ahead and let someone sell and replace your transmission but here is my suggestion! Check around and see if you can find a minor vacuum leak! This can simply be the big round hose that goes from the fuel injection to the power brake hub! This is normally a push in connector which has about a 1/2 inch hose clamped on it! If there is any kink or the connector is not in correctly a leak will occur and the transmission will shift rough as though you will be thrown out of the vehicle! Try unplugging this connector and plug it back in hard and straight and maybe you will be lucky and fix your problem. If the vacuum is correct your transmission will shift better than you have ever experienced!
Posted on Aug 16, 2009
racechef1957
  • 22 Answers
SOURCE: My 2003 cadillac deville-the service engine soon
On a lot of cars the light is reset when you get an oil change, air filter etc. It's overdue for a "look see". You can always go to advance auto and borrow the code reader for free. Plug it in under your dash and will read and reset any codes
Posted on Jun 14, 2010
  • 68 Answers
SOURCE: how do you cancel
It should be turn the key on and press the gas pedal to the "rug" 3 times and on the 3rd time hold it and it should reset itself.
Posted on Mar 13, 2011
SOURCE: My 1993 cadillac deville feels
The error is indicating that the Throttle Position Sensor (TPS) is out of the normal range with respect to the Idle Speed Control (ISC). Try something really simple and inexpensive first by removing the air ducting between the air filter box and the throttle body. Clean the throttle body interior and throttle plate with a cloth sprayed with WD40. Turn the throttle plate by pushing it at the top with your fingers and clean the throttle throat behind the plate as best you can. Reassemble the ducting and ensure that there are no air leaks at the junctions and no splits. Turn the key to position 2 (engine not running) and depress the accelerator pedal to the floor and then back up again. Start the car and nine times out of ten that should fix it. The TPS measures the opening angle of the throttle plate. The TPS is device consisting of a circular carbon track with a slider, corresponding to the throttle plate, sweeping along it. It as three wires to it, two to provide the 0 to 5 volt range along the length of the carbon track and the third to measure the voltage at the contact point of the slider. To check the TPS measure the voltage of the middle pin of the connector when the ignition is at position 2 (engine off) as you push the throttle plate open and closed by pressing on the accelerator pedal. The voltage should alter in a smooth continuous way. Any drop outs of signal indicate a worn carbon track and the TPS should be replaced.
Posted on May 09, 2011
Please help; my Cadillac Concours 1995 use fuel ? tooooooooo much in 100 km use ? 35 liters (9 gallons) without any smoke or missing. What is problem and how can I fix it????
Cadillac DeVille Mileage ' Fuelly
www.fuelly.com > Cars > Cadillac
There are 53 Cadillac DeVilles with reported gas mileage parked at Fuelly. ... Any Submodel, d'Elegance (1), DTS (1), Concours (2), DHS (4), Base (13), Other (32) ... 4 Vehicles; 27 Fuel-ups; 5,215 Miles Tracked; View All 1995 Cadillac DeVilles ... 2 Vehicles; 9 Fuel-ups; 1,664 Miles Tracked; View All 1991 Cadillac DeVilles.
Used 1995 Cadillac DeVille Features & Specs - Edmunds.com
www.edmunds.com > ... > DeVille > 1995 DeVille
Edmunds.comFeatures and specs for the 1995 Cadillac DeVille including fuel economy, transmission, warranty, engine type, cylinders, drive train and more.Missing: 100km
Cadillac history 1997 - Motorera
www.motorera.com/cadillac/cad1990/1997/cad97d.htm
History of Cadillac automobiles for 1997. ... 1997 CADILLAC DEVILLE ... Fuel Economy City/Hwy, 13.8 l/100 km - 9 l/100 km (20.4/31.2 mpg-imp) (17/26 mpg US).
Jan 25, 2016 | Cadillac Cars & Trucks
2002 cadillac deville service engine light flashing at 20 mph
Did you replace those parts based on the trouble code? Or are you just throwing parts at it? What are the codes?
http://ricksfreeautorepairadvice.com/flashing-check-engine-light-is-serious/
Aug 30, 2017 | 2002 Cadillac Deville
P0741
1983 cadillac's can not set these code's . pre OBD2 vehicles do not set P0741 codes .
Jan 06, 2018 | 1983 Cadillac DeVille
HOW TO TURN OFF SERVICE ENGINE SOON LIGHT 1999 CADILLAC DEVILLE ELEGANTE
first you have to found the problem and read the code , go to advance auto part and read the code , its free .
Nov 29, 2011 | 1999 Cadillac DeVille
Dont no my e codes definition on my 1993 cadillac deville i found codes E26,E32,E70,and E97 but I dont no what problems they represent
E26-shorted throttle signal switch
E32-open MAP sensor signal
E70-Intermittent TPS signal
E97-High RPM P/N to D/R Shift
some could be history codes not currents tho maybe try to clear then drive it and see what comes back.
Press off and high simultaneously to clear codes
and this link may help
http://www.cadillacforums.com/forums/ht4100-4-1-4-5-4/21558-obd-i-codes-4-x-engines.html
Oct 06, 2011 | 1993 Cadillac DeVille
My service engine light is on, took it was put on the machine and came back with the code po741 which was said to be a transmission problem. Took it to a transmission shop and was told that my...
Subject:
Service Engine Soon (SES) Light On, Diagnostic Trouble Code (DTC) P0741, Torque Converter Clutch (TCC) Excessive Slip, Transaxle Chuggle, Slip/Surge (Inspect/Replace Internal Transaxle Components) #04-07-30-034 - (08/06/2004)
Models:
1998-2002 Cadillac Eldorado
1998-2004 Cadillac Seville
1999-2004 Cadillac DeVille
2000-2003 Oldsmobile Aurora
there is a write up on this about 3/4 page down.
http://www.cadillacforums.com/forums/cadillac-forum/t-107360.html
Oct 25, 2010 | 2003 Cadillac Deville
Whath does "service engine soonmeans"
SERVICE ENGINE SOON and SERVICE ENGINE NOW are 2 amber warning lights pertaining to the vehicles computers.SERVICE SOON advises you of a problem, although not an emergency should be attended to promptly. Your technician can trace the problem by accessing fault codes through the climate control panel. SERVICE NOW indicates a more severe problem which will most likely precipitate a failure / breakdown. The CHANGE OIL LIGHT indicates by time and mileage is a separate light.
Mar 20, 2009 | 2000 Cadillac DeVille
2001 DEVILLE A/C Compressor a1z29394 8-279, 4.6L Logo
50 people viewed this question
Top Cadillac Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
John Totten
John Totten
Brian Williams
Brian Williams
Are you a Cadillac Vehicle Part and Accessory Expert? Answer questions, earn points and help others
