Question about Novelty 96512 Cuckoo Phone
  • 4 Answers
Are you trying to get it in time say to run faster or slower? If so the leaf should just slid up to speed it up or down to slow it down as it is only a friction fit. Hope this helps
Posted on Feb 08, 2009
My coco clock want stop cocoking
Hello, Leonard -
Clarification: Do you mean a cuckoo clock?
You may not be able to keep the clock from making the cuckoo sound unless you want to stop the clock from running completely.
If the sound can be stopped, there may be a switch to turn it off on the back.
A clock repair expert may be able to stop the cuckoo sound for you, for a price.
Best wishes.
Feb 10, 2018 | Coco Computers & Internet
Cuckoo and action doesn't work
Is this a mechanical cuckoo, or an electronic? If mechanical, probably the strike mechanism is jammed. You might barely, HEED: just barely pull on the weight a tiny bit and see if this does anything. If not, time to get it serviced. If it is an electronic cuckoo, check batteries and contacts.
Nov 04, 2017 | The Watches
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
How do I set the time on the run away clock
press and hold the "I" button for 3 seconds to switch between 12 and 24 hour mode
Jun 24, 2014 | Nanda Clocky The Running Away Alarm Clock...
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at
Mar 08, 2013 | Watches
Do cuckoo clocks need to be certified to be real?
There is a Black Forest Clock Association. They certify cuckoo clocks that are made from wood and made with parts produced in the Black Forest region and that meet the standards set by the association.
Feb 11, 2013 | Home
Timing is off bad on the cuckoo part of the clock. It won't stop and runs till the weight hits the ground.
We had the problem with ours when I was a kid. What we did on ours was to turn the hands until the clock cuckoos. Then we removed the hands from the stem and placed them back at the correct time. Hopefully, you can remove the hands from the stem without a problem. Don't force it however. Good luck.
Feb 01, 2013 | Watches
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
1/8 inch movement of the pendulum bob is equal to about 3 min per 24 hours running.
-To increase the time of the clock, move pendulum up.
-To slow down the time move, pendulum down.
Regulation notes:
These novel clocks are at best only a "fair" time-keeper. You can expect 100 to 120 sec per 30-hour winding period. I recommend that if it is within a few minutes per winding, simply RE-set the time.
-The regulation obstacles are obvious:
1. Open pendulum, this allows even the slightest breeze from a fan, ceiling fan or even cross-winds inside your house to affect both time qualities and/or its running ability.
2. The Pendulum material is wooden, and sensitive to climatic condition, during times of high humidity the clock will slow down.
Hope this tip helps.
Jan 26, 2009 | Novelty 96512 Cuckoo Phone
Novelty 96512 Cuckoo Phone Logo
188 people viewed this question
Top Novelty Lands Phones Experts
Are you a Novelty Lands Phone Expert? Answer questions, earn points and help others
