Question about Acer Aspire One PC Notebook
THE BOTTOM BAR ON THE LINUX DESKTOP HAS DISSAPEARED
The bottom bar on the linux desktop has disappeared (showing wireless connection, battery level, volume e.t.c.) and there is now a grey box with a star shape on the desktop saying that a new item has not been configured yet. also will not connect to the internet Any ideas? it is linux not windows
  • Anonymous Mar 10, 2009
    I had the same star like bar saying new item not yet configurated.
    People on the net suggested going to the Panel menu by running xfce-setting-show in the run menu (alt F2) and then delete any panels after the first. But that didnt work for me. I did get the star to move to the bottom of the screen. But now I need to find out how to get the icons back on the bar.
U might have to reconnect to ur network (exp.linksys) to get to internet access but also u might have accidently right mouse clicked on the bottom bar and clicked lock the taskbar so try right mouse clicking on ur screen when not on another program and click personalize or right mouse click where the task bar used to bar and some how unlock it. hope this helps!
Posted on Jan 26, 2009
2 Suggested Answers
  • 7 Answers
SOURCE: The bottom bar on the
get microsoft windows!!!!
Posted on Feb 17, 2009
Lost internet connection linux mint 14
Installing your wireless driver on a Linux distribution is only half the battle.
Once it's installed, you have to configure it.
This means adding the network name, or SSID (service set identifier), and the passkey for your wireless network.
In older versions of Linux, this had to be done with the "iwconfig" command line tools.
Luckily, Linux Mint has incorporated a graphical utility for configuring your Ethernet and wireless adapters.
Open the "Control Center," which will be found under the main program menu on the bottom right of your computer screen.
Click the "Network Connections" icon under the "Internet and Network" section.
Click the "Wireless" tab in the "Network Connections" window.
Click the "Add" button.
Type the name for your wireless network in the "SSID" text box.
Choose one of the options under the "Mode" drop-down list. Most users will choose the "Infrastructure" option.
Click the "Security" tab.
Choose your network's security protocol from the "Security" drop-down list.
Type the key for your wireless network in the "Key" text box.
Click "Apply" to save the changes.
Click the network connection icon in the task bar. It will look like two computers and can be found next to the clock.
Click on the name of your wireless connection to connect to the network.
http://www.linuxmint.com/wiki/index.php/MintWifi - The_network_manager.
Activate a Wi-Fi Card for Linux Mint
Log into Mint as user root. Launch a command shell, either by logging in in text mode or by launching a Terminal window from the graphical desktop.
Type the following command into the shell:
iwconfig
Press "Enter." Make a note of the name chosen by Linux Mint for your Wi-Fi card it will be the only word displayed flush with the left edge of the screen.
iwlist wlan0 scan
Replace "wlan0" with the name of the Wi-Fi card you noted earlier.
Press "Enter."
Mint will display a list of the wireless networks in range that you can potentially join.
iwconfig wlan0 essid library-wireless
Replace "library-wireless" with the name of the network you want to join, from the list generated by the "iwlist" command. Linux Mint will join the network.
At this point you can browse the Web and access the Internet in other ways via the Wi-Fi card on your computer.
http://linux.die.net/man/8/iwlist
http://linux.die.net/man/8/iwconfig
Getting Started with Linux Mint
http://linuxgazette.net/137/lazar.html
Aug 07, 2013 | Computers & Internet
Missing battery indicator in the task bar
No this is more typical with Windows Vista users as updates can disable the icons from the notification bar.
Chose 'taskbar' tab, then click 'customize' and chose the option for the battery icon and change to 'show' .
If you need anymore help please post back.
Regards.
Nov 26, 2009 | Microsoft Windows XP Home Edition
Linux Desktop blank
type in this in terminal command and it should restore your desktop to it's default settings: rm -rf .gnome .gnome2 .gconf .gconfd .metacity
Oct 20, 2009 | Acer Aspire One PC Notebook
Eeepc has no icons, just blue screen, can't access anything! Linux
When I was using Linux, there were 4 screens. On the bottom an icon showed which screen I was on. If you have that Icon, click the main screen (upper left) and you should be OK. Let me know if this works.
May 25, 2009 | Asus Eee 701Sd Notebook
The toolbar has disappeared
Ok, on windows desktop screen right click your mouse, select personalize, click on TASK BAR AND START MENU, pop up will show select TOOLBARs, then check Quicklaunch.
If icon is missing just create short cut to your desktop, then click and drag, then delete shortcut in desktop screen.
This is for vista.
As for XP it should be properties for personalize, then search for the link.
Leave a comment if this is not the exact one.
regards
Apr 25, 2009 | Acer Aspire One A150-1006 Notebook
Battery icon disappeared from bottom of screen
Right-click on your desktop
Click Properties
Click "Screen Saver" tab
Click "Power" button
another window will appear that says "Power Options Properties"
click "Advanced" tab
check "Always show icon on the task bar" click apply
Apr 03, 2009 | Acer Aspire One Netbook 8.9" Notebook
Desktop problem
It is possible that the task bar is in 'auto hide' First thing you should do is rest your cursor on all four sides of your desktop for a few seconds and see if it appears. If it doesn't than move your cursor to the bottom of the screen and right click and choose 'properties' and uncheck the 'auto ide box'. I am not positive that this well solve your problem, but its the best I can do at the moment. I well research it and find more info, than I well post it for you.
Jan 20, 2009 | Acer Aspire One PC Notebook
I've somehow hidden my Eee PC linux desktop icons; bar down the bottom shows, and all else is black, with mouse visible. How do I get the icons back?
what is the loaded OS on your EeePC?because I ran across this issue before and it was more than a hidden icon.
Nov 19, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
746 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
