Question about Archos 704 WiFi Digital Media Player
Headphone socket broken on archos 704
External speakers pluged in to archos704,speakers fell pulling 704 n snappin jack
    Problem Solver:
  • 13 Answers
Depends if the circuit board is damaged. If not and competent technicial should be able to repace the socket. If the board is damaged it will need replacing, unfortunatley this is coded to the hard drive so it is only possible if it is performed by Archos
Posted on Jul 16, 2009
For Christmas I received an Archos tablet and my headphones jack stopped working. Instead of playing sound through headphones while they're plugged in, it plays through the built in speakers. Is there
Every thing is low quality chines junk these days and probably head phone jack input is broken and it is not repairable as all similar items ,
Jan 13, 2015 | Archos Tablets & eReaders
When i am putting my audio jack in port the dection is shows but sound does not come from the speakers
It would be great to see screen shot.
Which windows do you have ? Are you sure speakers work ?
Try checking mixer is it set to headphones instead of speakers ?
Try pluging in other speakers (headphones) to see if it works.
Oct 14, 2013 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
External speakers
notebooks has a mini jack socket on the sides or in the front..look for the headphone socket..it is colored green and with a headphone icon on its side..this is where you connect your external speakers
Jan 13, 2012 | Dell Vostro 1000
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
Headphone jack does not cut out speakers when in use
This happens when you didnt insert the jack properly in the socket. Please insert th jack properly,it sholud be fully in.
thanx
Jul 20, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
Can't mute inbuilt speakers
That is not a software problem.
The headphones/external speakers jack socket has a switch to exclude from audio the internal speakers, when a jack plug is connected.
This is a very simple device and is not software controlled.
The fact that it has gone faulty at the same time you reinstalled the system is a coincidence.
If it does not mute when you insert headphones, all you can do is trying to play with the jack plug , inserting and pulling it out. If this does not unlock the switch, the alternative is having the jack socket replaced by a technician. This is generally an expensive repair, asthe socked is soldered on motherboard.
A cheap alternative to a proper repair is using an external USB to Audio Adapter and mute the internal audicard when using headphones.
Oct 19, 2008 | Computers & Internet
Headphone jack broken speakers wont work
Yes, since the Headphone pin is stuck in the Jack, you are not getting audio from Speakers.
You should have noticed that connecting the headphones to the Jack will block the audio coming from the Speakers and the same is the current situation.
You can either try removing the blocked part using a Tweaser or get it repaired.
Jul 31, 2008 | HP Pavilion dv9000z Notebook
Compaq C740TU speaker does not deactivates if external speakers are connetced
The internal speakers should automatically be disconnected by inserting a 3.5mm jack plug in the audio out socket. It may be that your headphones or external speakers are using a 2.5mm jack which is too small to operate the switches in the audio out socket. Purchase a 3.5mm jack plug [cheap] and plug this in if it disconnects the laptops internal speakers then you need to connect accesories with the correct size plug.
Mar 14, 2008 | Compaq Presario 700US Notebook
How to connect to nbg334w
Change the WEP mode on the Archos to 64 bit, it sounds like you have different modes set.
Dec 27, 2007 | Archos 704 WiFi Digital Media Player
Archos 704 WiFi Digital Media Player Logo
107 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
