Question about Ac Delco Oil Filter Nissan D21 89 88 87 86 1986 1987
How to get a stucked oil filter off - Ac Delco Oil Filter Nissan D21 89 88 87 86 1986 1987
  • Nissan Master
  • 14,363 Answers
What's it stuck on Heather?
Posted on Jan 20, 2013
Chevy oil filter stuck on
try a different type of oil filter wrench, the type that fits on the top of the oil filter, like a wrench that fits on a nut. Be sure the filter is really clean too, any oil on it can make the wrench slip. When you put it back on put a but of oil around the seal so it doesn't get stuck again.
Jul 31, 2013 | 2007 Toyota Sienna
Just changed the oil it ran fine for 30 mins. then started losing power .parked it checked it the next day all the oil was on the ground checked all obvious things . no cracks plugs n pan . used diff oil...
sometimes the old oil ring from filter stays stuck , i suggest you take oil filter down and make sure that the old ring is not stuck up there good luck
Mar 23, 2011 | 1997 Toyota Camry
Oil is leaking from gasket and from oil filter
Not sure what gasket you're referring to but if it's leaking from oil filter I suspect the gasket from old oil filter is stuck under gasket of new oil filter. They stick sometimes.
Mar 22, 2011 | Chrysler Neon Cars & Trucks
Oil filter seal keeps pop in out when I start the car 1999 Buick regal 6 cyl
The only time I've ever seen an oil filter gasket pop out on startup is when the gasket from the old filter had stuck on and the filter was thus installed with two gaskets. If that isn't the problem, It sounds like the oil pressure bypass valve is stuck and the pressure is building WAY too high. If you have an oil pressure guage, it would read very high.
Feb 15, 2011 | 1999 Buick Regal
2003 FLHTCI OIL Filter Stuck, bike has oil cooler, the cooler moves but the oil filter won't budge. It's a K & N filter with nut on the end, I've tried all kind of wrenches still stuck. Now I have a...
Somebody over tightened the filter. Your only choice is to force it to turn in any way possible. I've had to resort to sticking a screw driver through the filter to get enough torque to remove them. Good luck
Oct 23, 2010 | 2003 Harley Davidson FLHTC Electra Glide...
Leaking oil around the oil filter. is there a special filter to use on this car? I bought it used and it didn't start leaking until i changed the oil myself. and it only leaks when it is running
Oh, one should make sure that the old rubber gasket didn't get stuck on the engine block where the filter is. Sometimes, people change their own oil and don't look at the old filter they took off, to see if the gasket came off and stuck to the engine block.
In that case, the new filter has a gasket, and the old gasket is stuck to the block, and you have two gaskets stuck together, which will leak.
This is a common mistake to happen on any car.
Good luck on this repair.
Sep 20, 2010 | 1992 Honda Accord
Oil is leaking from around the oil filter
The rubber O-ring from the previous oil filter most likely stuck to the engine when filter was replaced. Remove oil filter and ensure only 1 rubber O-ring is sealing the oil filter to the engine.
Jun 19, 2010 | 2004 Nissan Titan
LOOSING OIL FROM FILTER THAT WILL SWELL UP WITHIN A VERY FEW SECONDS CAUSING COMPLET LOSS OF OIL AND WILL AUTOMATIC LOOSEN THE FILTER SO IT WILL COME OFF WITH A LIGHT TURN TO REMOVE IT
I had a problem kinda like yours once. It took me a while to figure out why but finally found that from a previous oil change the rubber gasket from the old oil filter had come off and stuck to the car so when I would put a new oil filter on that has a new gasket I was ending up with 2 rubber gaskets on at once.
May 15, 2010 | 2000 Pontiac Montana
Can't get the oil filter off
http://cgi.ebay.co.uk/Motorcycle-Oil-Filter-Wrench-to-suit-Honda-Kaw-Yamaha_W0QQitemZ280278909229QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item4141ecc12d&_trksid=p3286.c0.m14
this is the tool you put in a ratchet it will fit yours but remeber to put oil on the black seal on the new filter this is why it got stuck anyway buddy
Sep 15, 2009 | 2004 Honda VT 600 C Shadow
Oil leak behind oil filter
you probably have the old gaskket still on the filter or the filter receptacle. Remove the filter and check to see if the gasket is on the filter. Then check where you screw it on there may be the other gasket stuck to that.
Dec 26, 2008 | 2004 Hyundai Elantra
Ac Delco Oil Filter Nissan D21 89 88 87 86 1986 1987 Logo
80 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
