Wen I turn on air con. Portable CLAUSEN switch of all the time after 3mins of starting time I try to set the timer but didn't work thanks
    Genius:
  • 1,669 Answers
Timer switch is broken. Replace it.
Posted on Jan 20, 2013
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
  • 659 Answers
SOURCE: Timer operation Daikin BRC1C517 wired remote (Air Con)
http://www.daikin.co.uk/Product_Operation_Manuals/Controllers/default.jsp
Follow the link above. This is where you find the manuals for these units. I couldn't find the one that is specific for your unit but they do have a way you can contact them and also you might gain enough info from the ones they do have to figure yours out.
Posted on Mar 20, 2009
  • 20 Answers
SOURCE: air con trips off
i think MCB isn't enough replace 20A MCB
Posted on Dec 10, 2009
SOURCE: LG AIR CON - thermistor fails
Yes - I've got the same problem too. Unit is less than 6 months old, so not happy!
Posted on Jun 17, 2010
hvac1960
  • 2133 Answers
SOURCE: air con not working. Operation
First check your timer on and off. If you want to reset, remove batteries from remote and power off to unit. Reset it. Now run the unit. Set temp mode once again in your remote and wait for 3 minutes. If still out door unit not working, check power line to out door unit.
Posted on Dec 31, 2010
Have a pnosonic inverter which we have tried to set the timer on a number of ocassions only to find the air con starts on its own during the night for example we tried to set it to start at 5:50am and it...
Your thermostat may have a "learn" feature that learns how long it takes to get to your target temperature by the time you set (instead of start at the time you set). To get to the target temp in time, it has to start early. There is no way to turn it off on some units, other units may have an on/off feature for "anticpate", "target", or "learn".
Just bump back the time by 30 to 45 minutes.
Jul 11, 2011 | Televison & Video
I have a Danby Silhouette 10,000 BTU portable A/C.. it has recently stopped turning on. The panel with buttons lights up and works, but the unit itself will not turn on. Any ideas on what the problem is?...
If the unit was set in Automatic Timer Mode, it will not turn ON until the set time is reached. Try deactivating the Timer Mode. If that doesn't work. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. During this timeout, the unit should have time to reset itself, so that when you plug it back in and turn it ON, it will have reverted back to the original factory settings.
If you have misplaced your Owner's Manual, I have included a link to a Danby Model that is similar to yours, in the way that it functions. You can download and print the manual for future reference if you like.
http://www.danby.ca/cms/uploads/products/en_manual/DPAC10011_DPAC10011BL_EFOM_v2.pdf
I hope this helped you. Please let me know. Thanks.
Jun 28, 2011 | Danby DPAC10031 Silhouette 9,000 BTU...
I NEED TO SET THE AIR CON UNIT TIMER BUT DONT HAVE THE MANUAL? CAN YOU PLEASE LET ME KNOW HOW TO DO IT? ref no:- ASYA18 LCC WALL MOUNTED AIR CON UNIT
Simple! First set the time, if it is. And press timer on and set the time and same to timer off. If no time function, press timer on it will show 00.30 to 24.00 hrs. Set as per your need.
Dec 08, 2010 | Fujitsu Heating & Cooling
I HAVE A AN ISSUE WITH PORTABLE AC IT DOESN'T BLOW COOL AIR
dear sir
please make sure first your air con,s compressor is working if it, working and it,s not getting cold then it can be low gas problem or if compressor is not working then please check the thermostat settings and make tempreture correct and setting on cool mode
then i hope if it,s only normal problem then your air con will work again .
after that if not get cold then contact to air con technician for repair it (it,s need to repair and only air con special maintenance person can do it)
thank you
hope answer the question
please vote!
Sep 24, 2010 | Amcor A12000E Nanomax Portable Air...
Want to use the timer but have no manual to help me
dear sir /madam
please check your remote set there will be one TIMER button please select that and set there timer on position then select the hour and minutes setting .after that your air con timer will being on .if its still now not enable position then please contact to your air con maintenance personnel for further action .
please vote!
thank you
Sep 06, 2010 | Heating & Cooling
I need a manual for a Clausen kyd-32/a portable air conditioner
http://www.search-document.com/pdf/1/clausen-air-conditioner-kyd-32a.html
Nov 11, 2009 | Heating & Cooling
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
