My 40 GB Seagate hard drive has bad clusters in its D drive.
Format total hdd some virus effect
load ur OS
Posted on Jan 26, 2009
My internal harddisk locked when boot Seagate Barracuda 7200.7 ATA 40 GB
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 16, 2011 | Seagate Barracuda 7200.7 40 GB Hard Drive
How to make IDE slave hard drive?
You can make it slave with jumper settings check in back side of harddrive you can see jumper which is connected to 2 pin of harddrive.
Read instruction on harddrive you can read how to set jumper for make it slave.
Then you ca use it as slave.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 01, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
0x10090 error in st94011a hard disk
bad cluster.....or partition table!!!!
boott up winpe minicd....and make some changes...dnt forget format!!!! gd luck
Jul 13, 2009 | Seagate Momentus 40 GB Hard Drive
Unable to load os
check the operating system Cd could be bad version, try other one, if still the same , format your harddrive long way not the quick way.
Jul 11, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hard drive failure
You can replace the hard drive, but you will need to reload the Operating System from some other source, as it sounds like your Hard Drive is dead.
Mar 10, 2009 | Seagate (9W2041-337) 40 GB Hard Drive
Bad cluster in hard disk
You must run scandisk utility in windows to fix problem. Go to C: drive >> properties >> tools >> choose error checking >> select automatically fix errors >> then start >>
If proplem persists you must format the C drive there may be less chance of bad sector recovery...
Or contact your manufacturer tech support if your hardisk in warramty period.
Jan 03, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Sep 24, 2007 | Seagate Barracuda 7200.7 40 GB Hard Drive
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
