Question about Fuji FinePix Z10fd Digital Camera
When i try to look at my pictures it says error or something!!!
My camera was fine until i found out that one day i was scrolling through the pictures using the left button so then i clicked the right one and it didnt work!!so then i kept on playing with the camera and it repaired and now again !i was using it and i wanted to see the picture and i clicked the preview button and it said error or whatever!and now i cant fix it!!!!
    Brigadier General:
  • 5,158 Answers
You can download the manual here
http://www.fujifilm.com/products/digital_cameras/index.html
Please take a moment to rate this solution thanks
Posted on Feb 02, 2009
E1532 comes up on my screen and won't take any
E1532 signifies # events that have occurred , not an error...you probably have something like P0198/E1534...go into setup until delete images NO;press select;up down arrows to get flashing YES;select..then scroll to delete events NO;press select up or down, select.
Aug 31, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My camera will not let me see the pics I have taken.
Format Internal External both memory,and go to menu and Reset to factory default
Mar 17, 2010 | Polaroid t1031 Digital Camera
Card error on Agfa digital camera
Get a card reader (they don't cost much) and download your pics to your computer. Then, put the card back in the camera, go into the menu and scroll to "format" and follow the on-screen instructions. This will erase and optimize your card. My advice, don't leave your pictures on the card for very long...get in the habit of downloading on a regular basis and format the card regularly.
Nov 16, 2009 | Cameras
Canon Elph Sd1200 Communication Error
This question comes up several times a day here in the camera section at Fixya. But please note, it's very hard to troubleshoot individual software problems online, and it likely is a software issue. But why put up with the headaches of bad software in the first place?
Please don't take this as a sales pitch as it's not, but please see the following blog article, as it describes the use of an inexpensive card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jun 30, 2009 | Canon Cameras
RGB Histogram will not turn off.
It's not hard... I had the same problem, but I found this solution on the internet and it worked.
First turn on the camera and press the play button.
You are now viewing your picture with the histogram.
Use the same joystick looking kind of button that you use to scroll left and right through the pictures, but instead of going left and right, go UP OR DOWN. That scrolls through the different display settings.
Hope that helps!
Dec 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Button stuck, casuing unrepsonsiveness in all other buttons
Most buttons on a camera are a simple raised rubber pad over a printed circuit board. The button gets pressed, a concuctive material on the bottom of the rubber pad puts a short across a printed pad. If the camera senses a short across the down button, it will ignore all other buttons. You need to take the back off the camera and the rubber button pad will probably be right in the back, clean the contact with an alcohol Qtip and you should be OK.
Nov 23, 2008 | Leica D-lux 3 Digital Camera
Hi, I have a Canon Power Shot S2 IS 5.0 megapixels that was working fine until one day I changed the memory card from 512MB to a 1GB. Now every time I turn the camera on and try to take a picture, a...
Its possible that there may be an error on the camera try to reset the camera by
1. Turn the mode lever to the camera or play button
2. Press and hold the MENU button for more than 5 seconds.
3, The message "reset settings to default?" appears
4. Use teh arrow buttons to selelct ok. then press the SET button.
5. It should then reset the camera.
AFter doing that and the problem is still there. Format the memory card using the camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 06, 2008 | Canon Cameras
FujiFilm FinePix A500 screen turns off when trying to take a picture
I had the same problem with a fujifilm finepix... It didn't take pictures with 2 sony batteries, just turned off after pressing the shutter. Then I tried 2 panasonic batteries and it worked fine....
My solution: try panasonic rechargeable.
Oct 24, 2007 | Nikon COOLPIX P4 Digital Camera
Memory card problem
Assuming your camera acts like a removable drive when connected to the PC try the following.
  1. Right click the removable drive(your camera) in my computer and go properties>tools>error checking>tick both boxes>ok
  2. Wait till it finishes and check if you can now view the contents of the card. And copy to safe place straight away.
  3. Try http://www.officerecovery.com/freeundelete/ to recover any deleted files or fragments of damaged files.
  4. Let me know if any of this works.
Oct 22, 2007 | HP Photosmart M525 Digital Camera
Fuji FinePix Z10fd Digital Camera Logo
69 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
