I am not able to connect to internet because i don't have ethernet controller therefore i need ethernet controller
  • podgkin Mar 06, 2009
    I have the same issues...Gateway 610 (Elonex-Exentia) needed a re-install and no CD with it.
    Ethernet controller and Network Controller both yellow bang in device manager...?
    Someone must know - there are loads of us out there now? :(
I used Everest Ultimate to scan the system...
And discovered that the system had Intel PRO 100 VE based LAN settings/parts...I dunno? :lol:
I went to downloads.intel site and literally grabbed the full drivers pack for that setup, for my XP Media system.
TA-DAAA!!!! Ethernet is back and all is sweet.
(Hope this helps anyone else!)
Posted on Mar 12, 2009
    Sergeant:
  • 306 Answers
The ethernet controller is a hardware device either as part of the motherboard -where you will have an RJ45 connector visible to you at the outside of the case -or as a Network Interface Card (NIC) which would be installed as a PCI card which has it's own RJ45 connector.
If yours is a driver problem you will need to specify which brand/model computer or NIC you have for a link to that manufacturer to download drivers from that site. If you encounter problems or have more specific information please post again here. Steve Medley
Posted on Jan 26, 2009
Ethernet controller
That yellow exclamation mark means you don't have the correct driver for your ethernet card.
You didn't say if your operating system was 32-bit or 64-bit so I'll give you links to both versions of the driver.
Here is the 32-bit LAN driver:
http://img.dfi.com/Upload/Driver/CM/Marvell_LAN_729.zip
Here is the 64-bit LAN driver:
http://img.dfi.com/Upload/Driver/CM/Marvell_LAN_731_x64.zip
If you need any other drivers for your motherboard you can get them here:
http://www.dfi.com.tw/DFI-Lanparty/support/MBDriverDownload.jsp?selectedDriveritemId=349
May 24, 2012 | DFI LanParty UT 915P-T12 Motherboard
Can not connect to internet with TL-WR340G
try to unplug and replug ethernet cord. if the ethernet port has no blinking lights try to change ethernet cord.
May 16, 2012 | D-Link DI 514 Wireless Router (DI-514)
How can i get an acer aspire 5100-3357start normaly without a ethernet cable after resetting back to factory
You don't need a ethernet cable to start a computer. Ethernet cables provide internet connectivity. Exactly what is the problem you are having?
Apr 23, 2012 | Acer Computers & Internet
I use a cable internet connection which works. When I connect the router, I ran cable to blue connection on router and another ethernet cabel from the computer to another port on the router. When I do...
Turn the cable-modem off.
Turn the router off.
Use an Ethernet cable to connect the cable-modem to the 'WAN' (or 'INTERNET') port on the router.
Use another Ethernet cable to connect one of the 'LAN' (or 'NETWORK') ports on the router to the network-port on your computer.
Turn the cable-modem on, and wait for its lamps to settle-down to a steady pattern.
Turn the router on, and wait for its lamps to settle-down to a steady pattern.
On your computer, you should be able to access the Internet.
Also, look at the colour of the EIGHT wires at each of each Ethernet cable.
The order of the coloured wires should be IDENTICAL at both ends.
Jun 26, 2011 | Buffalo Technology Buffalo Wireless-N...
MODEM CONNECTION NOT FOUND
click start control panel admistrive tools,computer management,device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver,disable,uninstall or select properties general you will have the options to troubleshoot or to update driver,rollback or uninstall
a yellow? question mark means you need to install/update driver right click to install driver
also you might check
make sure your modem/routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps don
Feb 25, 2011 | Computers & Internet
My pc has room for one ethernet cable and its already taken to a router box. i have no idea what its for but now there seems to be nowhere to hook up my 360. i want to hook up for xbox live and netflix....
Simply put
You need to plug your xBox 360 into the Router not the PC.
The Router should have more than one ethernet slot. (That is what is generally meant by the term Router).
Therefore:
1. Plug one end of the Ethernet cable into your xBox 360.
2. Plug the other end of the Ethernet cable into an available slot on the Router.
If your Router is constantly connected to the Internet then this should solve the problem. If it is not, then connect to the Internet via your PC and then when the internet is on the xBox should find it.
Hope this helps. Regards,
Feb 09, 2010 | Microsoft Video Game Consoles & Games
What are the two ethernet for? Does it let you plug in both and you can use both at the same time, therefore downloading faster than one or something?
No you can't download any faster with 2 NIC ports.
In a typical setup where a PC has 2 NICs, one is setup as the connection to the internet and the other can be used to interface with any device that is Ethernet capable (home video cameras, alarm systems, home control systems, etc). However, the other NIC can be connected to another network.
You can even share an internet connection though a wall NIC throughout the home.
This means 1 for the internet and the other for networking to another hub/server or computer.
Regards.
Nov 13, 2009 | ASUS A8N-SLI Premium Motherboard
On my Laptop I only see conector for Dial Up internet "Thelephone Line conector" I don`t see Ethernet Conector and i have DLS Modem i been using whit my dell Desktop how do i conect the modem to my...
Install drivers for ethernet card or buy a usb to ethernet adapter. That will get you on the net so you can install your other drivers via thinkvantage installer. Or you can just cruise the net with the usb to ethernet adapter itself.
Nov 08, 2009 | IBM ThinkPad 770 Notebook
Computers & Internet Logo
358 people viewed this question
David Payne
David Payne
