Question about Lands Phones
I want to wire a telephone extention i have connectors 123 conectors and 456 my wires are blue greenwhite and red i would like to know the clour seqence
  • 79 Answers
2 and 3 are the British standard connections. On the wires side you shoud have a pair, which means one of the 3 wires will be spare. Give it a try. If you have connection on the wire, you should be ready to rock.
Posted on Jan 26, 2009
My shredder jammed so I took the top off of unit in order to clean. When I pulled the top back it pulled all of the wires loose. Being inexperienced I should have made a "diagram" of where the...
I'm afraid i cannot help you to tell you where each specific wire goes first because the wire colors mean nothing without sources and destinations but i can tell you this:Each wire has an elastic memory so that the shape it had before you opened it should remain the same. This means that you can deduce where each wire goes. Also you should have an electrician do the connections as there could be some voltage/amperage issues.
Jan 01, 2012 | Office Equipment & Supplies
What are the color of wires for the blue side, and the color of wires for the red side of the solinoid valve. my ge model is tfx25pryd.
If you look closer the connectors of the red coil are larger than the conectors of the blue side so they can not be mixed up. Here is a photo of your solenoid valve.
Aug 25, 2011 | Refrigerators
Power wires are 3? other then red & block wires what is next conector for?
You have 3 sets of wire connecting to the amp (besides the rca connection), Red is power from the battery, Black is the round wire (shorter the better), lastly Blue is the remote turn on wire. Without the remote turn on, your amp will not power up regardless of the power from the battery.
RCA connectors are for your audio, it carries the noise signal to your amp from the head unit...
Mar 21, 2011 | Phoenix Gold XS2300 Car Audio Amplifier
I need a diagram of the Ford Taurus 1995 spark plug wiring setup. I took them off but I think I placed the new wires on wrong. If you have an owners manual this would be even better.
firing order is 142536
looking at front of car the motor the belts to the pass side
cylinders will look like this
pass 123 coil pack is a little wierd on this car 4pin
side 456 connector
123
564
Jan 05, 2011 | 1995 Ford Taurus
Need of wiring diagram for driver's side window switches, or description of wires (colors) and placement on switches, on an 85 Carrera Thanks
Hello there
if you are replacing the switches the colors are as this
tho bottom conectors--red left-brown right-
The red is also goin to the t top connector
middle connectors --blue-black left--- blue-white right
top connector is only one and it is red (an extension from bottom red wire)
this should help you
trubka@yahoo.com
trubka
Oct 28, 2010 | 1984 Porsche 911
Our Phone wiring is underground and the connector box on the outside of mthe house was done in1978. My problem is that I hit the wires and some of them were knocked loose from the terminal and now I don't...
green wires and red wires.......... that is line one. also solid blue and blue with a white stripe is also line one..... so tie the greens and blue w/white stripes together and tape off (if not screwed down to block), and do the same with the red wires tied together with the solid blues.
yellow and black is line two.....and so is solid orange and orange w/white stripe. then just fill in the blanks as stated above.
its simple, think of the wires as speaker wire in a way to simplify what you are looking at. multiple Pairs (+/-) wires color coded. if the wires came off of the screw down posts, just match up the colors like stated above on the posts and screw them back down.
Nov 13, 2009 | Uniden 5.8GHz 2Handset Digital FHSS...
Trying to connect a teekonsha voyager brake control to a 2003 expedition
Their should be a 6 pin conector that only 4 pins are used somtimes a 5th wire is installed for illumination, don't worrie about using that one. The connector is located in one or two different spots, the most popular place is under the dash on the drivers side just below the steering column the connector is grey. The colors are black or red / blue / green / white and sometimes a small black or brown wire is for illumination, don't worrie about that wire. Their are wiring harnasses for sell to hook the brake control through the conector, but if you do not want to buy an adapter hook the wires as followed: Vehicle Brake Control
Black or Red Black
Blue Blue
Green Red
White White
Black is power in to the brake control
Blue is the trailer brake feed
Green is brake signal
White is Ground for the brake control
May 31, 2009 | 2003 Ford Expedition
Telex 56 to cobra 4 pin
Hi there!!
the yellw wire is not used on the microphone conector most of them are just cut and left in there loose as long as its not shorting out on anything!! The wiring for the telex 56 for your radio Cobra 29 LTD is as follows: PIN #1 Shield & Red, PIN #2 White, PIN #3 Blue, PIN #4 Black, Yellow wire not connected!!
If you notice when you have the connector apart on the back of the pins where the wires get soldered to the pins are numbered so you will know which pins they are or on the front side of the connector the pins are also marked wich numbers they are!! If you have any other questions please feel free to e-mail us at: bigdscbshop@hughes.net
Apr 18, 2009 | Telex M-560 Consumer Microphone
Plug wire order for a ford f150 4.2 engene
driver side from front 564 pass side 123 cylinders on truck run pass front to back 123 drivers side front to back 456.the first part of this paragraph is the coil pack wiring
Jan 30, 2009 | 1999 Ford F150 Regular Cab
Side View Mirror Wiring
Just try matching from the outside to the outside, middle to middle, etc. or use a continuity tester against each pair until the light up. Solder the wires, do not use wire nuts.
Apr 03, 2017 | 1996 Toyota Camry
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
