Laptop screen keeps getting darker - Computers & Internet
  • irish skin Jan 29, 2009
    Hiya, azzz949 & tans nut.
    this problem with the screen is on going now for over ayear and the only time it works is when i get the inverter replaced, which is more often than i would like.
    by the way if i connect to an external computer the laptop works perfectly. Which leads me to believe it is associated with the physical elements rather than the technical...also i dont know why their called laptops cos this machine cooks the lap off you after 5 minutes.
  • Azz
    Azz May 11, 2010
    Hi, please can you explain a little more. What are you doing on the laptop when this happens? Is it all the time or just sometimes?
  • 95 Answers
Is it happening when u do not use the laptop for few minutes??
Or it could be something to do with the power on the battery which is reducing due to usage. Screen would get darker to make optimum usage of battery and give longer back ups.
Posted on Jan 26, 2009
Dell Inspiron Screen Gets Darker
your screen might need to be replaced. soon you wont be able to see anything. replacing the screen should be an ez fix
Feb 28, 2014 | Computers & Internet
I get an intermittent shadow on the left-side of myscreen. Computer works fine, except at times I have the shadow.
If you mean that the left side of the screen goes darker than the right side, then this is an indication of a faulty backlight. There are probably two CCFL tubes, one on each side of the screen. If one starts to fail, then that side of the screen will get less light and look darker. The tube may need to be replaced.
May 25, 2011 | Acer Aspire One PC Notebook
The laptop screen freezes and fades out slowly becoming darker and darker. Moving the screen however helps restore it back to life for a short while
Hello
Ok, because the screen gets better for a little while if you move it, this might just be a simple connection problem. The thing is, and it is quit common on notebooks, is that the data cable linking the screen to the motherboard sometimes get a little loose. Hence, the screen still works, but not properly.
I would suggest that you open up the unit and just make sure that the data cable is plugged in correctly. If you do not feel comfortable doing this yourself, you can take it to your nearest computer repair shop.
Hope this can be of help.
Kind regards
Andrea
Aug 27, 2010 | Acer Extensa 4620 Notebook
The computer still works, just the screen keeps getting darker and darker.
check and see through hp if there is a driver that might have been installed from microsoft that caused this problem. if the drivers where changed put them back to the original drivers. if this started to happen after an update. check your update settings and turn off the automatic update from microsoft. it is some times better to see what upsdate is being installed before you let it.
May 14, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Screen getting darker
your case is the back lights inverter or lamp damage, you have to send to repair, find a laptop hardware specialist to do that, my repair cost (lowest)
1) repair the inverter board if repairable, $50
2) change the new inverter board $80
3) change the lamp $60
Feb 02, 2009 | Acer Aspire 5610-4648 Notebook
If your running windows vita, move your cursor to the top of the screen, and click brightness, or press Fn+F6
Dec 28, 2007 | Acer Aspire 5610-4648 Notebook
Tv screene getting darker and darker
Caps in high voltage needs changing, needs tech
Aug 19, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
