Question about Black & Decker & Leaf Hog Blower / Vacuum
Leaf blower black and decker hog wont blow - Black & Decker & Leaf Hog Blower / Vacuum
SOURCE: black and decker leaf hog on off switch schematic
Take out all the screws. Gently remove half of the case. Put a shim in behind the plastic pivot that rocks the switch. I rolled up a 1/2" by 3" piede of duct tape and jammed into the back of the oval socket for the rocker. This pushes the rocker against the switch hard enough so that it rocks the switch properly. Snap the case into place and test the switch before you put the screws back in to make sure it is now working properly.
Posted on Sep 27, 2009
rwvanlue
  • 486 Answers
SOURCE: Where can I get a new replacement bag for my Black
http://www.blackanddecker.com/CustomerCenter/parts.aspx
this link should help you with anything you need.
Posted on Nov 12, 2009
bbreton
  • 437 Answers
SOURCE: black and decker leaf blower is on all the time
go to www.dewaltservicenet.com. Put your model number in the site and it will come up with a parts list and diagram for your blower.
HTH
Good Day.
Posted on Nov 18, 2009
SOURCE: how do i change black and decker leaf blower to
you have to remove the plate that covers the fan bla des intake than witch hoses some covers are spring loaded and just flip up
Posted on Apr 22, 2010
SOURCE: My motor brushes at end
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Posted on Aug 31, 2011
How do I change from vaccum to leaf blower?
You haven't stated the model you're referring to.. Here's a link to a Black and Decker blower vac manual, but it might not be your model as I'm having to guess due to lack of info.
http://compsource.manualsonline.com/user-manual/black_decker/blower/bv3600
Apr 16, 2016 | Black & Decker & Leaf Hog Blower / Vacuum
I need to see the manual
Depending on your model and when it was made, there is a safety recall on these blowers
http://www.blackanddecker.com/support/safety-recalls/black-and-decker-bv4000-blower-vac-type-1
Nov 27, 2015 | Black & Decker & Leaf Hog Blower / Vacuum
How do I switch between vac to blow?
The long thin tube is for blow and the larger dia. tube is for vac. and usually mounts at the fan area on bottom of your machine. Do you still have your instruction book or the local home center where you purchased it, will answer this question and give direction. Good Luck...
Oct 25, 2012 | Black & Decker Leaf Hog Blower Bv4000
My motor brushes at end of life for a Black and Decker electric leaf blower. Where can I get them? Black and Decker leaf hog, model BV400 type 4, Cinderson 90510850 motor. Black and Decker site no help...
Good Luck!
Aug 31, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Where do I attach the bag for the vacuum?
When the machine is converted to vacuum mode, the collection bag will go on the machine where the blower tube (long part) is connected for blowing mode.
Mar 19, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Will start but wont run.runs only a second
It is possible that the ON/OFF switch is bad or the wires that connect to the switch are loose and are not making permanent contact. Check the switch.
Dec 04, 2010 | Black & Decker Leaf Hog 12-AMP Electric...
How to do I convert it from blower to vacuum..it just stopped sucking and the blowing is not strong
My LEAF HOG works fine on blowing - but when I switch to vacuum it wor't
start. What's the difference from going to Vacuum from Blower???
Dec 03, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
Need assembly instructions for a black and decker leaf hog bv4000
http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90538065,LH4500.pdf
Nov 27, 2010 | Black & Decker Leaf Hog Blower Bv4000
The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Oct 25, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Black & Decker & Leaf Hog Blower / Vacuum  Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
