Question about Hunter 27185 Remote Control
Tac 490 ver 1.1 remote control replacement - Hunter 27185 Remote Control
Chunghop RM-88E codes for syntax TV?
Try 490 or 492 or 493
I got this information from the code book 1, (from the link below)
Chunghop website downloads: Click Here
-Charles
Jul 03, 2016 | Universal Remote Control Televison & Video
Product manual
Pogo is normal. It will be normal always. No need to repair it.
May 26, 2016 | Televison & Video
When playing Mahjong Safari why don't I get the correct credit for the doubles I've matched?
Call USA POGO SUPPORT 1-631-490-0805 pogo Customer ...
Call USA TOLL FREE 1-631-490-0805 pogo Customer Service Phone Number/362 pogo phone number usa pogo (SERVICE+SUPPORT)..!!1-631-490-0805!! pogo t.e.c.h.n.i-c-a- l Support Ph.one Number pogo tecH suPPort Numbner!!((1-631-490-0805 )) Intuit pogo Enterprise Customer support Phone Number Help@Call 1-631-490-0805/. pogo 24/7 support phone number, pogo telephone number for support? call 1-631-490-0805@./ pogo contact number, pogo contact phone number, pogo contact telephone numbertele phone
May 14, 2016 | Pogo.com Video Game Consoles & Games
It will not accelerate. I push on the gas and it won't go. I changed the oil a week ago and about a year ago i changed the fuel pump
Well an oil change is probably not the cause.
What IS it doing? You're telling me what it isn't doing...
Does the motor rev up?
Jun 10, 2015 | 2002 Chevrolet Tahoe
07 Aveo error codes p2110 and p161b. Can this be a bad battery?
code p2110 refers to throttle actuator control (TAC) system-forced limited rpm mode (limp mode)===causes wiring--tac motor- APP sensor--ECM
it also refers to heated oxygen sensor(HO2S) 1 bank 1 implausible signal===causes wiring .--short to positive-- short to ground--HO2S sensor---ECM
Check/replace the HO2S sensor and check the APP sensor and TAC motor.
Nov 02, 2014 | 2007 Chevrolet Aveo Sedan
I have codes 0122 0123 2104 2110 2111 2112 would it be the throttle body
Trouble Code: P0122
Throttle/Pedal Position Sensor A Circuit Low
Possible Causes:
Open ETC TP sensor harness.Short to ground in the ETC TP sensor harness.Damaged TP sensor.SIG RTN circuit open to the TP sensorPCM has failed
Trouble Code: P0123
Throttle/Pedal Position Sensor A Circuit High
Possible Causes:
TP sensor not seated correctly.TP sensor harness is short to voltage.TP sensor harness short to VREF.SIG RTN circuit open to the TP sensor.Damaged TP sensor.PCM has failed.Trouble Code: P2104
Throttle Actuator Control (TAC) System (Forced Idle)
Possible Causes:
Air cleaner and air inlet are not correctly seated.Check for self-test DTCs in all of the vehicle modules.Accelerator Pedal Position (APP) sensor.Throttle Position (TP) sensor.Manifold Absolute Pressure (MAP) sensor.PCM has failed.
Mustang 2006-2008
4.0L V6 VIN N Auto 12
Print
Trouble Code: P2008
Intake Manifold Runner Control (IMRC) Circuit Open (Bank 1)
Possible Causes:
IMRC monitor circuit open
Trouble Code: P2014
Intake Manifold Runner Position Sensor/Switch Circuit (Bank 1)
Possible Causes:
IMRC monitor circuit openMechanical concern - bind, seize, damage or obstruction of IMRC hardware
Trouble Code: P2015
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 1)
Possible Causes:
Mechanical concern - bind, seize, damage, or obstruction of IMRC hardware
Trouble Code: P2019
Intake Manifold Runner Position Sensor/Switch Circuit (Bank 2)
Possible Causes:
IMRC monitor circuit openMechanical concern - bind, seize, damage, or obstruction of IMRC hardware
Trouble Code: P2020
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance (Bank 2)
Possible Causes:
Trouble Code: P2065
Fuel Level Sensor B Circuit
Possible Causes:
Communication link concernDamaged Instrument Panel Cluster (IPC) (MKS)Damaged Instrument Cluster (IC)Damaged PCM
Trouble Code: P2066
Fuel Level Sensor B Circuit Range/Performance
Possible Causes:
Trouble Code: P2067
Fuel Level Sensor B Circuit Low
Possible Causes:
Trouble Code: P2068
Fuel Level Sensor B Circuit High
Possible Causes:
Trouble Code: P2070
Intake Manifold Tuning Valve (IMTV) Stuck Open (Bank 1)
Possible Causes:
IMTV signal circuit shorted to PWR GND or SIG RTNDamaged IMRC actuatorPCM has failed
Trouble Code: P2071
Intake Manifold Tuning Valve (IMTV) Stuck Closed Bank 1
Possible Causes:
IMTV signal circuit shorted to PWR GND or SIG RTNDamaged IMRC actuatorIMTV circuit openPCM has failed
Trouble Code: P2072
Throttle Actuator Control (TAC) System (Ice Breakage)
Possible Causes:
Ice or oil in the intake air system could be the result of a Positive Crankcase Ventilation (PCV) system concern
Trouble Code: P2096
Post Catalyst Fuel Trim System Too Lean (Bank 1)
Possible Causes:
Loose connection, and damaged or corroded terminalsExhaust leaksContaminated HO2S
Trouble Code: P2097
Post Catalyst Fuel Trim System Too Rich (Bank 1)
Possible Causes:
Trouble Code: P2098
Post Catalyst Fuel Trim System Too Lean (Bank 2)
Possible Causes:
Trouble Code: P2099
Post Catalyst Fuel Trim System Too Rich (Bank 2)
Possible Causes:
Trouble Code: P2100
Throttle Actuator Control (TAC) Motor Circuit/Open
Possible Causes:
TAC motor has an open windingTAC motor is damagedTAC motor harness is openTAC motor harness is short to PWRTAC motor harness circuits are short togetherTAC motor harness connector is unplugged
Trouble Code: P2101
Throttle Actuator Control (TAC) Motor Range/Performance
Possible Causes:
TAC motor circuits are cross-wired
Trouble Code: P2104
Possible Causes:
Air cleaner and air inlet are not correctly seatedCheck for self-test DTCs in all of the vehicle modules.Accelerator Pedal Position (APP) sensorThrottle Position (TP) sensorManifold Absolute Pressure (MAP) sensorPCM has failed
Trouble Code: P2105
Throttle Actuator Control (TAC) System (Forced Engine Shutdown)
Possible Causes:
Trouble Code: P2107
Throttle Actuator Control (TAC) Module Processor
Possible Causes:
TAC motor harness circuit short to ground.TAC motor harness circuit short to voltage.Damaged Electronic Throttle Body (ETB).PCM has failed.
Trouble Code: P2110
Throttle Actuator Control (TAC) System (Forced Limited RPM)
Possible Causes:
Trouble Code: P2111
Throttle Actuator Control (TAC) System (Stuck Open)
Possible Causes:
Binding throttle body, stuck open.TAC motor circuit open.TAC motor circuits are cross-wired.TAC motor harness circuits are shorted together.PCM has failed.
Trouble Code: P2112
Throttle Actuator Control (TAC) System - Stuck Closed
Possible Causes:
Oct 26, 2012 | 2006 Ford Mustang
No throttle response
What you replaced is the APP(accelerator pedal position) It is part of the electronic throttle control,what was truly needed is know as the TAC MOTOR. This recieves signal from the APP.The TAC is what accelerate the car.The only thing you can do other than replace the TAC,is do a TAC relearn .Turn thhe key off. wait ten seconds,Turn key on with the engine off.leave 1 minute. Turn key off start the vehicle you will hear the TAC motor setting itself.
Mar 08, 2012 | Saturn Cars & Trucks
Cmo se programa un contol remoto dedish para q haga una sola funcion
tengo 2 tv con 2 diferentes controles pero uno no funciona y mis dos tv tienen la misma programacion por decir el control #1 controla las dos y el control # 2 no tiene ningun mando hayer el 1 y2 trabajaban correctamente y podia ver dos diferentes programaciones
Feb 18, 2011 | DISH Network IR Remote Control
Code for Zenega satellite receiver for DishTV DTH service India
dish tv code ver 154 code 15935764
ver 123 code 86427531
ver 155 code 6834
ver old code 9009
Oct 27, 2008 | GE JASRM24912 Remote Control
Televison & Video Logo
76 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
