Question about Crosley Washing Machines
Crosley cfw 8000 front load washing machine does not drain
Washing machine stopped working. will not drain
3 Suggested Answers
  • 53 Answers
SOURCE: I have the CFW-8000 washing machine. When the
It sounds like the timer showing 1:09 is the time in minutes (109 minutes = 1 hour 49minutes) which is approximately the same as your own timer shows.
The soap dispenser often gets blocked and you will have to remove it and clean away all the residual, built up soap.
It sounds like the drain plug in the base of the unit has become blocked and that is why the soap dispenser is filling with water. All the water SHOULD DRAIN THROUGH the dispenser when it washes the soap down into the washing machine.
Also sounds like your water or fabric softener is blocked too!
Take the plastic parts out and clean away all soap residues.
Posted on Nov 18, 2009
  • 2468 Answers
SOURCE: crosley front load washer one year old. doored
your drain pump or hoses are blocked with foreign material,either coins,hairpins,detergent residue from earlier washings,remove the front lower access panel if provided to access the drain hoses and pump and also check the drain itself,some washers have the access door in the back side of the machine,if the stand pipe in the house is slow to drain it can back up and cause back pressure and the machine will sense this and stop also
Posted on Nov 11, 2010
How do I access the drain pump on a crosley front load washer model number cfw4700lwo
Thank you for your post, derek dion!
From the information you have provided you need to know how to access the drain pump on your Crosley washer. I was unable to locate a step by step instruction sheet on how to access the drain pump. From your parts manual you would need to remove the front panel and it is located directly under the drum. If you are having trouble locating it or removing the front panel I would recommend contacting a professional technician for proper disassembly and repair. Best of luck! -OOS
Feb 22, 2015 | Crosley Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
E20 code flashing Crosley washing machine
E20 is a draining issue. You probably have objects obstructing the drain line.
May 06, 2012 | Crosley CW5000 Front Load Washer
Hi my washer moter works but spin cycle is not working Every thing else is O. K Thanks
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 29, 2011 | Crosley CAWC529JQ Top Load Washer
Nov 18, 2009 | Crosley Washing Machines
My washing machine will not rinse or spin in any mode
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Nov 13, 2009 | Crosley CAWC529JQ Top Load Washer
Crosley CW6000 Washing Machine. When my washing machine is in the spin cycle, it shakes severely and the machine on the floor
My Crosley Cw6000 wash will not spin the water out, I lift the lid to watch the spin cycle, it spins but the water does not drain..
Sep 02, 2009 | Crosley CW6000 Front Load Washer
Crosley CFW8000GR OE Problem
Have you called Daewoo Customer Service they make this product for Crosley the number is 877-393-7823 Also have you checked to see if anything is stuck in the pump.
Jul 18, 2009 | Crosley CWDH11W Front Load Washer / Dryer
I have the Crosley cfw8000gr front load washer and dryer. The washer stops when its ready to drain and the letters on the dislay say OE. I have cleaned all of the filters and hoses however it still stops...
Open the small door on the front of the machine and take out the strainer for the pump i think you have something stuck in the pump also be carefull when you put the strainer back it is kind off tricky to line up.
Washer wont drain and spin properly
whee is th drain filter on crosley front loader
Apr 02, 2009 | Crosley CW5000 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Gerry Harvey
Gerry Harvey
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
