Question about Dual Electronics XDMA6415
Dual XDMA6415 no sound
Its a brand new unit that I installed today. Everything works on the display as it should but there is no sound at all whether CD, tuner, or ipod
Speakers cut out
Can have 1000 causes, like bad cabling, in power cable as loudspeaker cable. Defect in amplifier, or defect in the power supply of the amplifier, bas fuse, to name a few of the possibilities.
Mar 12, 2015 | Dual Electronics XDMA6415
I installed a DUAL XHDR6435 to my 1991 Ford Explorer XL the radio works fine got sound and cd functions but the display is all out of whack everything that can light up on the display is on the display...
I Would try the reset button on the back off the cd player if there is one...If not shut it off and back on...U may have to tinker with the controls for a bit to get it conform to your liking....
Jan 26, 2014 | Dual Electronics XHDR6435
How to fix my xdma6415 sound is not working
I am assuming you are referring to the DUAL head unit for a car. Is this a new device or something you have used previously? Who did the wiring etc? Are there any external amps powering your system?
Nov 21, 2013 | Computers & Internet
I just recently bought a brand new MTX magnum amp and dual 10" enclosed subs deal off of amazon. They arrived today, and with the help of a friend who is good with car audio systems, we set the whole
the best thing to do is get in touch with amazon,and see what they can do about it,if you try to fix the problem yourself it will invalidate the garantee!
Dec 05, 2012 | MTX Car Audio & Video
I have a CDA-9855 Alpine head unit. It worked just fine when removed from my prior vehicle (05 VW Golf). I just installed it in an 01 Land Rover Discovery II using a wiring harness adapter so no cutting or...
it sounds like you have the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) turning on an external amplifier in your rover. the antenna remote wire turns off when you leave tuner mode.
Jan 26, 2011 | Alpine CDA-9855 CD Player
When head unit is on tuner everything is fine when on ipod or cd mode there is no sound ...i have taken off the face and reset the unit and still tuner sound on ipod and cd sound off
are you using an amplifer? if so, it sounds like you are using the blue wire instead of the blue/white wire to turn the amp on. the blue is antenna remote and turns of when it is not in tuner mode. the blue/white is amplifier remote.
Oct 28, 2010 | Alpine CDA-9883 CD Player
Pioneer AVH P6500DVD Tuner Failed
sounds like the antena plug on the back of the unit came out pull out an check
Jul 15, 2010 | Pioneer AVH-P6500DVD Car DVD Player
MEX-BT5700U, no sound in speakers in CD source, tuner source OK.
What many people do on this model is connect the remotes wires improperly. Use the solid blue wire for the amp and the blue with white stripe for the connection to the car.
Dec 06, 2009 | Car Audio & Video
No sound in Windows 7
Uninstall all the audio drivers and restart the computer. Make sure the audio jack is in the Green audio port.
Let the operating system re-detect the audio and install the drivers for it itself. When its done see if you have any sound.
Post back if this does not work.
Good luck.
Nov 17, 2009 | Microsoft Computers & Internet
Whether it is good ang easy to use micromax mobiles .........wat is the success rate of this mobile....
Today's big brands are yesterday's new brands. Similarly today's new brands are tomorrows big brands.
Everything is there with the service and the performance. As far I'm concerned you can go with Micromax.
I own Micromax Q5, It's really very cheap, but we can do a lot with Q5. I bet you no other mobile can beat Micromax in cost and performance, as per today's date.
-Cheers...!!!
Mr.Maduraikaran.
Sep 25, 2009 | Nextar Q3 GPS Receiver
Dual Electronics XDMA6415 Logo
Top Dual Electronics Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
xxxxxx xxx
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
