Question about Car Audio & Video
Mtx rt-x02 install help - Car Audio & Video
Can i hook up my MTX electronic crossover rt x01a to myvhome reciever
yes you can. you need a 12v power supply for you home. Purchase a 12v 5a supply and set it up like you would in a car.
Nov 10, 2013 | Car Audio & Video
Tryin to hook up a mtx electronic crossover rt-01a. i dont know how to hook it up
Your basic crossover is going to have a power (+) and ground (-). Your power wire goes to the battery, and your ground goes to the frame. You will need to hook up your RCA or speaker wires to the input side. Then hook the other two RCA connections to your amp.
Apr 13, 2011 | MTX Car Audio & Video
Fast blinking red light
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Good L .A thumbs up would be greatly appreciated if this answer is helpful to you. MTX Audio
Aug 13, 2009 | MTX X Thunder 1000XD Car Amp
Rotten foam rubbers
You can have "The Speaker Factory" re cone them. Call for an est.first Generally gonna be less expensive to replace.
Jun 25, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
Dont know how to set my crossover! mtx rt-x03a
This unit had a couple unique features: a center channel (summed) output and a differential output (right channel is subtracted from the left). Once you figured out you lows, mids, and highs. Center and rear. I recommend buying a cd to test out your sounds like your high, mids, and lows
Mar 06, 2009 | Car Audio & Video
Rs 232 command Sony FWD32LX1R
Hello, i found the solution:
Screen off
^x8C^x00^x00^x02^x00^x8E
^x8C^x00^x00^x02^x01^x8F
Kind regards
Roger
Jan 05, 2009 | Sony FWD32LX1R Television
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
