Question about ASK Proxima DP6860 Plus Multimedia Projector
Dim Image The image on this projector is about half as bright as it should be. changing the bulb does not help.
  • George Roach Jul 16, 2007
    The new bulb was bad. We tried another new bulb and the image brightness is good. thanks.
  • Anonymous Mar 18, 2014
    Where is the bulb located and how to change it
    Genius:
  • 2,985 Answers
Check you manual for a dual brightness control that may be activated or even stuck at low level. The manufacturers web site may have a technical help team to consult - have you tried?
Posted on Jul 16, 2007
  • john ash
    john ash Jul 17, 2007
    Thanks for coming back
    glad you sorted it.
SOURCE:
Time to change bulb??
Check the lamp. It might be faulty. [low light intensity]
May 11, 2012 | Vivitek D732MX DLP Projector, 3200 ANSI...
Projection is so dim
Click HERE for the user manual.
I hope this helps.
Goodluck,
Please don't forghet to rate the solution
Mar 22, 2008 | HP Digital Projector Vp6120 Multimedia...
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
The projector is not giving a bright picture. The image on the wall is very dim
I you were using the projector in the same room with the same ambient light and if you notice this problem try increasing brightness, if still the brightness is not sufficient then it is time to replace the projector lamp.
If you have moved your projector to a different place, check if the existing light / ambient light in that room is making the image look dull / not so bright. If this is the case, try to reduce the ambient light
Mar 09, 2011 | Dell 1100MP Multimedia Projector
The image is very dim, even on maximum brightness. We are considering replacing the bulb, but bulbs for this projector are very expensive and we suspect that since there is some image, the bulb is not the...
Yes, as bulbs age they will begin losing brightness. Most projectors have a bulb life hour clock, that measures the number of hours a bulb has been used. Usually you can pull that up within the menu of the projector. Also that particular model has what is called "Eco-Mode" and when engaged dims the bulb by 25% to cut down on power consumption.
Typical life for a lamp in that projector is:
3000 hours on Normal mode
6000 hours on Eco mode
You can expect a brightness loss of 50% when you are approaching end of a lamps life.
Mar 07, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
Projector works but image is very dim
Hello.
Here are 2 links for your Epson Powerlite 7300 projector:
User manual:
http://files.support.epson.com/pdf/pl53__/pl53__u1.pdf
User Replaceable parts list:
http://files.support.epson.com/pdf/pl53__/pl53__rp.pdf
And ... yes .. the replacement bulb for most projectors are very expensive.
Hope this helps.
Feb 23, 2010 | Epson PowerLite 7300 Multimedia Projector
Image is dim. How do I adjust brightness
You can adjust the brightness through the user menu, under the picture option. You might want to look at your bulb. It might be time to replace the lamp.
Sep 19, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Sep 05, 2008 | InFocus X1 Multimedia Projector
Hi there
Sounds to me like it is time for a new lamp.
Jan 23, 2008 | HP Digital Projector Vp6120 Multimedia...
Projection tv lamps
All fillament based lights will dim as they age. Some of the newer/better types it will be unnoticible.  If you are losing image quality or brightness you may have a bulb that is nearing the end of it's life cycle.  A glance at you owners manual or the manufactor's website should give you an indication of the expected life of your bulb.  Also most of the projector made in the past few years have a counter that tallies the amount of hours your bulb has been on.  A more likely culprit is probably dust accumilation somewhere inside your projector. Most projectors have filters these days and need to cleaned at certain intervals and in certains ways.  Not cleaning these filters can cause heat build up that can increase operating temps and shorten the life of your bulb and or projector.  Or sometimes jsut fail and cause a dramatic decrease in image quality.  Again these things are vendor/model specific so you will want to check with them about your particular model. Hope this helps.
Nov 24, 2007 | Panasonic PT-51HX41 51" Rear Projection...
ASK Proxima DP6860 Plus Multimedia Projector Logo
312 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
Steven Wander
Steven Wander
Vincent_G
Vincent_G
polytek
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
