Question about Belling XOU174 Electric Single Oven
My belling xou174 oven is not heating up fully
Power to the elements but not heating up fully
suspect faulty thermostat is this correct
  • 44 Answers
Hi
have checked to see if the element is open circuit with a muiltmeter? because if you are getting power to the element but no heat the the fault will be the element hope this helps you
regards dan
Posted on Mar 19, 2009
Belling cookcenter oven over heats and light stays on
It sounds like the people who changed the elements did not connect them to the correct wires. The thermostat seems to have no effect on the elements, and the light switch seems to have no effect on the light, explain this to them and that you think they fitted the elements directly onto the power input to the device, instead of the correct connections.
Dec 14, 2013 | Ovens
Tip
How to diagnose, fit and change a Belling fan oven element
If your fan oven is not heating up properly the Fan Oven Element for your Cooker is usual culprit. Fitting an oven element is generally very easy, as demonstrated by The Apart4u video on How to change repair and replace your fan oven element:this fan oven element can usually be changed without taking the appliance out of situ.
on Aug 25, 2010 | Belling XOU174 Electric Single Oven
Vulcan Comenda VC200 Wiring Diagram Series: 200/31/0166
Hi i have a belling DF951 fan oven .the heater element stays on when the oven is switch off .Is it the thermostat that is faulty because i can not leave it on .I HAVE TO SWITCH THE MAIN SUPPLY OFF.Or the oven stays on all night
Aug 23, 2013 | Belling XOU174 Electric Single Oven
Replaced element on belling synergie on 2 occasions in the past 6 months. What could be the reason for them blowing?
fan on in oven but not heating up just after the power tripped think because of oven this is not the first time this has happened can you help please
yours shane
Mar 10, 2011 | Belling XOU174 Electric Single Oven
We have a fan oven, which started not heating, but fan and thermostat light still on! We thought it was the element! But now the oven is working very occasionally, still heating as normal! We can try to...
Elements don't heat intermittently - if the element is good it will heat up every time. If the element is blown / burnt-out it wont ever heat.
As your oven is heating sometimes but not others, this means the power supply to the element has an interruption somewhere. This could be caused by any of the following:
1. Loose connection in the wiring at the switch or the element
2. Faulty switch
3. Faulty thermostat.
4. Faulty oven timer
The thermostat is effectively just a heat-sensitive switch. By default it should be "closed" allowing power to the element. When the oven reaches the desired temperature, this switch opens, cutting power to the element until the oven cools enough for the switch to close and allow power to the element again.
Any of these four could be the cause of your fault. Loose connections can often by located visually, however testing a thermostat for correct operation and calibration is more complicated and ideally requires test equipment. The timer is the least likely cause, so I would concentrate on the others first.
Repairing your oven or any other electrical appliance can be dangerous and many repairs require specialist knowledge and/or electrical test equipment. Please bear this in mind before and when attempting any repair or consider having your appliance professionally inspected.
If you are intending to investigate this problem yourself, please ensure the power is disconnected at the wall/breaker first. Initially, I suggest that you visually check the connections at the element and the switch. You may find a wire at one of these locations that is partially broken or detached. Personally, I suspect your thermostat may be faulty.
Hope this helps.
Regards,
BElectric
Jan 01, 2011 | Ovens
Belling built in fan oven (XOU60FP)is overheating
Have same problem, I am repairing our 648HM double oven. Top oven overheats. I am an electronics engineer. I found that top oven fan has failed, this is the first thing to replace. The grill element also failed which maybe due to the overheating oven. NIGEL
Apr 03, 2010 | Belling XOU174 Electric Single Oven
The fan is running in the oven but generates no heat
it may cause because of the damage of the heating element in the oven,.
Mar 27, 2009 | Belling XOU174 Electric Single Oven
My xou174 oven is not heating up elements are sound and have power faulty thermostat??
hi
if you have checked the elements then the chages are the stat will be faulty. does the little neon light come on when you turn the stat on? if it doesnt the the stat will be the problem
regards dan
Jan 26, 2009 | Belling XOU174 Electric Single Oven
Belling Synergie fan oven.
the elemet has burned out round the fan
Dec 05, 2006 | Belling XOU174 Electric Single Oven
Belling XOU174 Electric Single Oven Logo
174 people viewed this question
Top Belling Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Belling Oven Expert? Answer questions, earn points and help others
