Question about Iomega (33090) 250 GB Hard Drive
Where can I get the Vista driver required for DHD250 n3
I require the vista driver for my iomega DHD250 n3
  • ssjsolomon May 24, 2009
    Firewire (1394) will not work with Iomega DHD250-C in Vista. USB works fine. Followed Microsoft's "workaround" (editing registry) and all it got me was a change from code 10 to code 43. Firewire worked fine with XP.
    Vista tells me my driver is up to date. Any other suggestions?
    For those of you who care to try, here is Microsoft's solution:
    http://support.microsoft.com/kb/927827/e...
    I did read of one fellow who got his external HD working with a 1394 Firewire cable by following these steps. Didn't work for me.
4 Suggested Answers
fire sine
  • 382 Answers
SOURCE: Unable to install IOMEGA HDD on Vista Home Premium
Vista may require drivers that are not preinstalled. If the drive clearly works on one machine, but not another, its safe to pressume its not the drive. On the VISTA machine, go to the Iomega site and download the driver for vista or usb or whatnot.
Posted on Oct 22, 2007
SOURCE: My Vista machine can't see the iomega network drive
You need to connect to the IOmega drive using windows xp and add a user.
In the explorer view in Vista at the top click on Map Network Drive.
At the bottom click "Connect using a different username" and enter the credentials that you created earlier.
In the box above for the location type in "\\IOmega's IP Address\Folder that you want to map".
Click on connect at the bottom should be done straight away and then you should be able to see it in "Network Places" as well. Let me know if this fixes the problem or not.
Posted on Sep 11, 2009
  • 10406 Answers
SOURCE: REQUIRE WINDOWS 7 DRIVER FOR
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Posted on Nov 05, 2010
I can't access or upload data on my Iomega device since my upgrade to Windows8... any solutions out there please?
Your Iomega device requires drivers and I think that they will work with Win7 but not the obsolete Win8 version. Return to your old OS to enable it to work.
Jun 16, 2017 | Iomega Computers & Internet
Iomega floppy usb-powered external floppy drive on windows 8
Hi, Sounds like driver related problem to me. Try use this tool to update the drivers: Driver Update Software for XP Vista 7 8. Wish you best of luck.
Nov 30, 2012 | Iomega Floppy USB-Powered External Floppy...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
Nov 05, 2010 | Iomega Silver Series External 250GB...
How do I connect the scanner for windows Vista through the USB port? I have a parellel to USB adapter. Does it require any additional drivers?
That scanner is quite old now, and will require drivers for vista.. i wouldn't imagine that you could get vista drivers for it now unfortunately, which is a shame because that was a great scanner.
just out of interest, you could try googling "umax astra 2100u vista drivers" and see what comes up... i dont hold much hope though :-(
Sep 01, 2010 | Umax Astra 2100U Flatbed Scanner
Sound is not comming when i change window XP from window vista
Your PC requires a more recent soundcard device driver that is compatible with Windows Vista.
You can download the required driver here-
http://support.acer-euro.com/drivers/desktop/aspire_t180.html#driver
Please be aware that there is a different driver for Microsoft vista sp1 and above as opposed to Microsoft Vista. SP means service Pack which is a combination of updates supplied by Microsoft to make your operating system more reliable, secure etc.
If you do not know whether you have SP 1 installed, click on the start menu, right click on the computer and click on properties. Your Windows operating system is now described in the top of the window. It will say something like Microsoft Vista or Microsoft Vista SP1.
//javaftper
Aug 02, 2010 | Acer Aspireā„¢ T180 PC Desktop
I have a compaq presario c700 running windows vista. On my previous laptop I was able to record successfully using Audacity. Now, however, recordings are very poor - the sound comes and goes, and is of...
Stuart, make sure have the System requirements Here are the recommended memory (MB or GB of RAM) and processor speed (GHz) requirements for using Audacity with different versions of Vista:
Version Recommended RAM/
processor speed Minimum RAM/
processor speed Vista Home Basic 2 GB / 1 GHz 512 MB / 1 GHz All other Vista versions 4 GB / 2 GHz 1 GB / 1 GHz
Note that the minimum system requirements as defined above (i.e. those that allow the operating system to run, ignoring what is required to run applications) are much greater than for Windows XP. If your computer does not significantly exceed these minimum requirements then you may have problems doing more intensive tasks in Audacity such as recording for long periods or editing a large number of long tracks, or may need to close other programs and processes before you can do so. Please be aware that the cheapest "deals" for new Vista machines may well only include the Vista Home Basic Edition and system specifications little in excess of the Vista minimum requirements.
Other things being equal, 64-bit versions of Vista will require more RAM than 32-bit versions. While some users report Audacity runs fine on 64-bit Vista with 2 GB RAM, this depends on the number of tracks being worked with and the number of other programs and services running on the computer. Memory is now very inexpensive. The general recommendation for 64-bit Vista is to install a minimum of 4 GB RAM - and for very best performance, install the maximum RAM that your motherboard supports.
If you meet the min system requirements. Uninstall your sound card drives and try the beta version for Windows Vista.
http://audacity.sourceforge.net/download/
WBTech
Jan 19, 2010 | Apple iMic, USB Audio Interface Sound Card
How can I stop the iomega 1TB HDD crashing my laptop I run it with vista
this does sounds like corrupt driver or software for ur HD. also if this is vista 64 bit that might be too. vista 64 is pain and most times after windows updates whole hell breaks loose. try removing drivers and software for ur HD and reinstall without plugging it in until it asks u. Let me know
Dec 04, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
Do I need Gateway drivers for Vista Service Pack 1?
I think if you try to install vista you should be fine. just check the system requirements for vista to make sure your computer can handle it. If you have any special hardware devices then you might want to find any drivers for it and have them on hand just in case
http://www.microsoft.com/windows/windows-vista/get/system-requirements.aspx
Go here to check the system requirements
Dec 19, 2008 | Computers & Internet
Oct 18, 2007 | Iomega 32883 40 GB Hard Drive
Open Questions:
See all Iomega (33090) 250 GB Hard Drive Questions
Iomega (33090) 250 GB Hard Drive Logo
319 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
