Question about Tricity Bendix TM220W Electric Dryer
How to replace belt for a tricity bendix TM 220 w
3 Suggested Answers
SOURCE: Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Posted on Feb 09, 2010
  • 85 Answers
SOURCE: how do you replace belt on tricity bendix tm 470
remove top of dryer
Posted on Oct 25, 2010
Tricity bendix tm 550 motor spring adjustment
If there is no provision for adjustment, the spring may have lost its tension and will have to be replaced.
Nov 18, 2016 | Tricity Bendix Dryers
Tricity Bendix tumble dryer TM 560 will not Heating but drum is rotating.
Hi, it could be the heating element needs to be replaced, best get it checked.
Apr 05, 2016 | Tricity Bendix Dryers
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
Fit belt on Tricity Bendix TM 220 W Tumble Dryer Drum stopped rotating but motor running and element heating up. Took back off and belt seemed to have slipped off. Trying to reattach belt but it seems too...
Check the belt routing over the idlers near the motor, there is a spring tensioner, also make sure idlers are smoothly rotating and not seized.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 24, 2011 | Dryers
7. reassemble
Jan 30, 2010 | Tricity Bendix TM310W Electric Dryer
Tumble dryer running but not heating up its a tricity bendix tm 545
either element or thermostats have blown, is their a red button at the back of the dryer, if so push in and reset, if not need engineer to check out the above.
Nov 09, 2009 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix TM220W Electric Dryer Logo
Top Tricity Bendix Dryers Experts
Tim Whalen
ptpumpman
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
