Question about Whirlpool Washing Machines
LSN2000PW4 not getting water out - Whirlpool Washing Machines
Not leting water in on modelsyo424a
Have you checked the water valve solenoid with a volt meter to make sure your getting power applied when calling for a fill cycle? if you are getting power and you can hear the water valve make and not getting water into the sump tray then have you checked the water filter? Make sure water supply line is not kinked and you are getting water to the valve.
Oct 07, 2014 | Kitchen Appliances - Others
Water diagnose light blinking 0n cm3 scotsman ice machine even after changing water level sensor
Is the sump tray full of water? or is it not filling up fast enough? Water level sensor lets control board it needs water or its full of water. If machine is not getting enough water or slow filling then check the water filter, if water is flowing good through filter good then pull water line off of the water inlet valve to make sure there is no trash blocking water at inlet. If not then make sure the water solenoid is getting power call from board to solenoid, if getting 115v to coil and slow to no water to sump then replace valve, if no power to valve then replace board.
Sep 25, 2014 | Kitchen Appliances - Others
Ice maker not getting water. water despenser gets water
call chas&son,s at 570-379-0993 and they will come out the same day no less okay
Jan 30, 2013 | Frigidaire Puresourceplus Ice Water...
Do water filters get out 100% of the bacteria or small particles in the water?
even if you get the top of the line water filter on the market, it will probably say that it is only 99.9% effective
Jan 30, 2013 | Water Filters & Coolers
Hot water gets too hot trips off at tank then water gets cool and i push reset button and water gets hot again real hot thentrips off again
It's time to replace your thermostat. Instead of maintaing the correct water temperature, the water is getting so hot it is acivating the safety circuit breaker. If this breaker were to fail, you could have a devastating explosion
Mar 21, 2010 | RELIANCE ELECTRIC WATER HEATER
Whirlpool model lsn2000pw4 sounds like its spinning but its not
It appears your coupling/drive belt has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
No water to ice maker but I get from the water dispenser
Check the waterline as well as the valve supplying water to the ice maker.
Sep 27, 2009 | Freezers
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I am not getting water thou the ice maker nor the water dispenser
Check the water valve where the water supply line comes into your frig. If you are not getting any water at all then it seems as though there is no water getting to the frig through the water supply line or the water valve is bad or not getting any voltage to work properly.
Nov 14, 2008 | Whirlpool 21.7 cu. ft. Side-by-Side...
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
