Question about JVC HR-XVC20U DVD Player/VCR
Can I record from the VCR to the DVD ? on the JVCHR-XVC20U?
What disc should be used? DVD-R or DVD+R ?
Use DVD+R,
According to the claims of the DVD Alliance, using a DVD+R (or DVD+RW) recorder will provide the following advantages over a DVD-R recorder:
  1. Instantly eject without having to wait for finalized formatting.
  2. Ability to record one DVD disc partially on PC and partially on television.
  3. Background formatting: while the disc is being formatted, you can simultaneously record on already-formatted portions of the same disc.
  4. Enhanced ability to edit filenames, movie and song titles, and playlists.
  5. 100% compatibility with all other DVD players, while still enjoying these extra recording features.
Source: http://www.diffen.com/difference/DVD%2BR_vs_DVD-R
Aug 16, 2013 | JVC HR-XVC20U DVD Player/VCR
Jvc ht-xvc20u VCR/DVD combo player says "incorrect disc" error message every disc i try.
Have you tried a cleaner yet? It could be something as basic as needing the lens/compartment cleaned. They sell these kits at most retailers for less than $20. It is also possible them lens itself got scratched or cracked, especially of you've moved the unit recently. 5_19_2014_1_13_30_pm.png
Aug 04, 2013 | Televison & Video
Vcr tape . does not record to dvd-r disc Using hdmi cable from TV to recorder.
It is a HDMI OUT on the DVD/VCR Recorder.
You can only record to a DVD/VCR from the External DVD/VCR Input (Connected to a Freeview, Cable or Satellite Box etc) or from one to the other.
Jun 09, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I need instructions to record from vhs video player to dvd recorder
Connect the vcr to the dvd recorder via scart. Set TV to your usual dvd channel and power on dvd. Power on vcr and scroll through input channels (AV etc) on dvd recorder until you find the signal from vcr. Prepare the recorder ready to record, then play the vcr and start the dvd to record.
Sep 20, 2010 | Televison & Video
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Record from vcr to dvd
You need to get a set of RCA leads and connect ya Video to your DVD recorder, from VCR Video, Audio OUT to DVD Audio IN. Press play on VCR, and Record on DVD ya should be good to go.
Jan 26, 2010 | Philips Magnavox MDV530R DVD VCR
Repeat recording 5x week for same show
Found the solution in the on-line manual, around p. 33. Thanks.
Aug 14, 2009 | JVC HR-XVC20U DVD Player/VCR
DVD stuck in player
Find the small hole on the front of the player. Get a paper clip and straighten it out. Stick one end in the hole and the DVD should pop out.
Jun 05, 2009 | JVC HR-XVC20U DVD Player/VCR
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a Sony SLV-SE 710B VCR and a Sony Bravia HD TV I now wish to record my videos (about a 100) onto DVD. What Sony DVD recorder will take the output from this VCR and put it onto disc or do I have to...
You need to buy Sony DVD Recorder and hook Sony VCR to that dvd recorder and burn DVD directly. You can also watch VCR tape movie on TV via dvd recorder while its being burn on dvd.
Click Sony Style to select DVD recorder.
May 11, 2009 | Televison & Video
JVC HR-XVC20U DVD Player/VCR Logo
18 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
