Question about Samsung Dishwashers
Smasungdishwasher DMT610RHS error codeCE showsup. eventhough the is not locked in, it still runs with error code CE, but the water is not coming in. but the motor is running. unless I plugged out, it keeps running. I shut off, but not responding power ONOFF.no response to any button on the control pannel. but keeps running.
  • 87 Answers
SOURCE: Wash Motor Keeps running after water pumps out
You have a bad control board in the unit.
Posted on Jun 08, 2007
SolutionGuy
  • 331 Answers
SOURCE: bosch dishwasher motor keeps running no water
Hola Lewis!
This is such an easy repair, you'll be shocked and surprised! The reason this is happening is that the computer or timer has detected a "flood" condition and has permanently energized the drain pump to clear the "flood".
What you'll need to fix it...
1.) Shop-Vac (for vacuuming water) with a crevice tool (like one of these)
2.) T20 Torx bit with a driver. Torx sizing here. (You can get a set at Home Depot or Lowes)
All you gotta do now is get down on the floor and remove the kick panel. Then remove the screws holding the water valve and lift it up out of its' plastic holding. Now your shop-vac w/ crevice tool can be used. Stick the crevice tool in there (about 10") and vacuum up all the water that's been trapped in the basin. (you may need a flashlight to see what's going on back in there...) After the water is gone, your DW will work fine.
Here's how it works... About 10" behind the inlet valve is a "float" made of styrofoam. When water gets into the basin, the float rises and eventually trips a "flood condition" switch. This switch shuts the unit down and will only allow the drain pump to operate. So what you want to do is get the water out of the basin.
There may be a reason for the basin flooding, though. Suds (caused by too much (or the wrong) detergent), an actual water leak from the valve, etc... So after you get the water out of there and the unit is working again, you may want to monitor it (like, only run it when someone is home) for a while just to make sure that a real flood does not occur.
Hope this helps.
SG
Posted on Mar 23, 2009
  • 784 Answers
SOURCE: stay running in drain leaks for top left
When the machine is runing, the water is spraying bottom tube up to wash the dishes,
The lid is supposed to seal from the the top to prevent the leak. When you pull out the drwaer, you see the top groove, this is for this purpose. touching inside of the edge top lid , you will feel the seal around the edge, if this is bad it causes a leak.
However if this is good but the actuators from both sides left and right didn't not function by holding the lid down at the begining of the wash cycle, it also causes a leak.
I'm sure you have a leak, and the leak activate the floor switch to cause the pump keep running as long as the power is plig in. I didn't have to replace the floor switch after waiting for 48 hour drying out unplug power. Now the problem is to fin out whether the Lid seal or the actuator. To do that we have to fix the Draining problem so we can access the troubleshooting.
1- Un Plug the power.
2- Pulll the drawer halfway.
3- Dry out under the top lid seal as well as the enire surface if possible.
3- Put in a small tower from the left below the bottom drawer to dry out the wet area. There is only small access from the left, since the right will not have enough room to access.
3- Try to dry out all the surface area as far as you could reach.
4-After it is done, wait for 48 hours so the floor sensor can be dry out itself before plugging the power cord.
At this time No more pump noise is in running mode. Your problem is fixed as stated.
However, do not operate it since the root cause of the problem has not addressed yet, As soon as you run it, the same problem will happens again.
Let me know the progress and we can proceed to next level. I don't want to put the long procedure here to discourage you. Good luck.
BTW your current parts were from the first original design. The replacement parts will be from a better design point of view, and hopefully they will be the better ones.
Posted on Jul 05, 2009
  • 4 Answers
SOURCE: Dishwasher won't power off
Howdy. Flashing light on the switch, shows a glass? At any rate your overflow protection switch is activated. Probable cause; plugged or defective exhaust hose that does not allow pumping to go faster than water coming in, too high a water level. Clean the entire system first!
Is your exhaust hose going up to about threequarters as high as the machine? You must have this uphill twist and turn in the drain system.
A little water remains in the sensor and it thinks you are flooded. Force air through the pump in the floor until all is clear, a clean plumber's helper is ideal. Keep doing this until you get the last bit of water out of the sensor. When you get it running watch the machine (First time) carefully. You do not want a flood, that's why Asko put this safety device in place.
Posted on Nov 01, 2009
pnieto3
  • 5 Answers
SOURCE: light is on but no motor running, no water coming
the switch is no good, by a new one ...
Posted on Dec 13, 2009
What is CE error code on LG TROMM WM1814CW
According to page 21 of the owner's manual, the following are known error codes: IE= Water Inlet Error, OE=Drain Error, UE=Unbalance Error, dE=Door Error, tE=Thermistor Error, FE=Overfill due to Faulty Water Valve, PE=Water Level Sensor Error, CE and LE=different Motor Errors, and PF=Power Failure.
its a motor error
check the brushes
Jan 03, 2015 | LG WM Washing Machines
Fridge digital display is showing CE, WATER DISPENSER BOT RUNNING WATER AND MOTER IS NOT ON
Hi berniekeenan -
Error code CE typically indicates a communication issue between the user interface and main control board. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the refrigerator back on. If the error code continues, I recommend scheduling service so a technician can accurately diagnose and repair your refrigerator.
Apr 20, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Flashing CE CODE
try to clear error code
Aug 20, 2017 | Hayward Pool & Spa
Ce code on panel
Hi twillli62 - Typically error code CE indicates that the unit has detected a communication failure. A professional will need to check the wiring between the main control board and the user interface board. Depending on the actual diagnoses from the certified technician, either part will need replacing.
Jan 14, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does the OE light mean, ta the machine wont drain and spin and the light keeps coming on.
Here are error codes/:
OE= PUMP BLOCKED OR WATER NOT PUMPING OUT ( LOOK FOR PROBLEM IN THE PUMP IMPELLER )
IE = NO WATER INTO APPLIANCE CHECK WATER TAPS ECT
DE = DOOR OPEN OR NOT LOCKED
UE = IMBALANCED LOAD
SE = NORMALLY MOTOR FAULT BUT COULD ALSO BE MAIN PCB FIRST CHOICE IS CHANGE MOTOR.
CE = CURRENT ERROR SHORT CIRCUIT TO MOTOR OR MAIN PCB DUFF
LE = LOCK ERROR BASICLY WIRING TO THE DOOR LOCK IS FAULTY
FE = TO MUCH WATER IN TUB
TE = TEMPRATURE ERROR NORMALLY THERMISISTER OR ELEMENT FAULT
PE = PRESSURE SWITCH FAULT
Jun 18, 2009 | LG Washing Machines
My whirpol calypso washer don't running, appear fl and ce
"FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
• Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
• Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
• Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
• Drive motor thermal protector has opened.
• Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Mar 08, 2009 | Whirlpool Washing Machines
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
Dishwashers Logo
728 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
