Question about John Deere Garden
John Deere JS36 self propelled lawn mower does not run because it doesn't have any compression. When I pulled the head cover and rotated the motor by hand it appears that piston to valve relations
I bought the mower used and have never heard it run. Even though it looks brand new I know that it has been used some because there is grass clippings in the housing near the blade.
  • 708 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 1114 Answers
SOURCE: Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Posted on Jun 23, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
Troubleshooting
First guess is the flap that protects you from flying debris and grass. It must pass vertical and then be dragged under the mower when going from forward to reverse. c0fcb146-2ad7-49f7-900c-5183207e7c3f.jpg
Jul 26, 2014 | John Deere JA65 Self Propelled Mower
Lawn mower self propelled cable
John Deere Model JS38 Walk Behind Mower Parts
About half way down the page, left hand side. About $20.
Semper Fi,
Z
Feb 13, 2018 | John Deere Garden
How to clean carburetor on John Deere JS36 Lawn mower
Indeed, a dirty carburetor can prevent the John Deere JS36 from starting or running correctly. Mine had this problem. A video that helped:
http://www.youtube.com/watch?v=ArCAivgAyww
The video is more in depth than you need but basically shows you what to look for inside the unit. Essentially: Remove the air filter assembly from the carburetor (a couple of bolts). Clamp off the fuel line, disconnect it from the carb. Unbolt the carb from the mower (a few bolts). Disconnect the choke and throttle arms from the top of it. Unscrew the cup from the carb, clean everything out. I used compressed air for all the little fuel channels. Reassemble, reattach.
Jun 11, 2012 | Garden
Pull cord on john deere 190cc 6.75 hp
The housing might be riveted to the engine housing and might need to come off together. Hope this helps!
Jun 09, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Lawnmower won't start
is there spark?does it fire on starting fluid
Apr 21, 2012 | John Deere JA65 Self Propelled Mower
Have a walk behind 22"
Sounds like the rewind spring is broken in the recoil starter.
Aug 04, 2011 | Toro Power Lawn Mower
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
140 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
