Question about LG 32LG40 32 in. LCD HDTV
How to turn on SAP on LG 32LG40?
How to turn on SAP. Needed for vision impaired person.
DVD disc stuck in vision plusTV/DVD combo
There should be a tiny hole somewhere on the front of the DVD tray, where you put the disk in. If it's not on the tray itself, it should be very close to it. Bend a paper clip out a bit, and carefully press it into that tiny little hole, and the tray should open up. If that doesn't work, then it's physically jammed, and mechanically unable to open.
Jan 31, 2013 | LG 32LG40 32 in. LCD HDTV
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
I want to use European DVDs on an LG model 32LG40 which is in the US. Thanks
i think you need to change the region code
pls try
) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select Ok when congratulation message appears
Aug 26, 2010 | LG 32LG40 32 in. LCD HDTV
I have an LG TV/DVD Combo 32lg40. The DVD drive will not allow me to load dvd's how do I fix the dvd player on this TV
I have had this problem. Unplugging the unit from the power source for 5 minutes and plugging back in solved the problems. This has happend twice in 1 year.
Mar 19, 2010 | LG 32LG40 32 in. LCD HDTV
Need unlock code for TV/DVD player 32LG40
Presiona el boton de MENU en el control remoto y al mismo tiempo el de MENU en la TV, por unos 10 segundos, aparecera el password que de fabrica es "0000" despues entras a un menu y hasta abajo, creo que es la opcion 8 aparece cambiar la region del DVD, ponlo en WORLWIDE y podras ver cualquiere region
Apr 08, 2009 | LG 32LG40 32 in. LCD HDTV
Background voice, 27 inch "truflat" 2005 model
What you're hearing is the descriptive audio track included on many DVDs for vision-impaired viewers. Does this happen when you're watching regular TV or just with DVDs? If it happens with regular TV, do you have a cable box?
Regular broadcasting sometimes uses SAP (second audio program) to send additional audio, and this descriptive audio may be the SAP channel on some programs. Check your TV's audio settings to make sure you don't have SAP turned on. There may also be settings for SAP in your cable box as well, so check there too.
When playing a DVD, descriptive audio is usually an alternate audio track. Check your DVD player setting to make sure you've selected normal audio for playback.
Apr 04, 2009 | RCA TruFlat 27F520T 27" TV
Descripticve Dialog on SAP?
Sony usually has a button on remote....MTS maybe....push =
cycles....Main...SAP....Mono.....
SAP = second audio program...........................T.
Dec 03, 2007 | Sony KV-36XBR450 36" TV
LG 32LG40 32 in. LCD HDTV Logo
16 people viewed this question
Computer Repairing
Computer Repairing
