Question about IMSI TurboCAD Deluxe 10 for PC
Turbocad V10.2 will not work with Windows Vista basic
When I run the program it crashes all the time and some commands and functions are missing. The offset command (crucial) cannot be found.
  • Katman01 Feb 08, 2008
    OS = XP Sp2. When I try to run TC 10.2, it crashes and the program closes. It doesn't matter if I try to start new or open a previous file (it did work at one time). I also have TC 6 and it runs just fine, except, of course, it will not open the drawings made with 10.2. I have unistalled TC10.2 completely and then reinstalled and still have the problem.
  • Anonymous Apr 05, 2008
    Does not load correctly
  • 32 Answers
Well, turbocad deluxe 10 is NOT compatible with vista. Here is the compatibility list : Windows 98/Me/NT4/2000/XP Pentium-class PC 64 MB RAM (128 MB recommended) 55-212+ MB hard-disk space 64 MB of swap space Super VGA (1024 x 768) display High Color (16 bit) graphics card 4x CD-ROM drive with 32 bit drivers
Posted on Jul 17, 2007
Computer command line interface discuss
Well, in the very basic sense, some of the default Windows maintenance programs have a few added functions if you run them from the command line. For example, Defragmenter can be made to defragment boot files for optimization or a variety of other specialty commands.
For optimization of the installation process, you can use a command line to repartition a USB drive as NTFS and clone a Windows install disk by giving the partition boot permissions. This is simple in the command line but would require downloading and installing a third party program to set it up in a GUI.
Some solid state drive options, such as TRIM support, are only flaggable in the command line, and TRIM is a protocol very much necessary for the smooth operation of SSDs. Hard drive functioning and indexing can be controlled at the command line level in ways that are more complex than the simple options in the Windows GUI.
Aside from the task scheduler, a variety of small scripts can be devised in the command line to eliminate small time consuming tasks such as file renaming.
Learning to use the command line is a valuable skill for any computer enthusiast.
Oct 25, 2012 | Microsoft Computers & Internet
Programs crash with no explanation.
First I would Click Start/Programs/Accessories and you are looking for the RUN command. Sometimes depending on your operating system you will see it as soon as you hit Start or Programs or All Programs. Once you get the run commad open type in "msconfig.exe" and click ok. This is the system's configuration window, Click the Tab that says Startup. The only two columns you are concerned with is the Startup Item column and the Command column. You can expand those two columns by placing your mouse pointer between two columnar headings and it will turn into a + sign so you can drag the column to see more of it. Notice that all the items have a check mark beside it under the Startup Item column. That check mark means that this application will run everytime you start your computer. Now look for items that have a check mark beside them but there is nothing under the command column or location column. If you see that remove the check mark from the item, it's a virus that's trying to hide. Also look for Startup Items that have the command of: c:\Documents and Setting\Your Userid Account Name\Local Settings\Application Data\xxxxxxx . If after application data you don't see some recognizable program then remove the check mark. Most virus attach itself to a user account under the local settings and application data area. Also if you see a startup item "dumprep 0-k" or similar, remove the check mark from it. *** Don't worry about if you remove a check mark from something you are unsure of, you can always go back in and place the check mark on it. When done click Ok and select the option to Exit Without Restart. This simply stops the virus from being able to get started when you boot your computer. You will actually have to kill it with a virus protection scan in the next steps.
Now you can then run your virus protection scans to make sure you don't have a virus causing the problem. I would take the time to run Spybot Search & Destroy and also I would Run AVG afterwards. In fact after spybot search and destroy finishes, I would turn my computer off, then turn it back on and immediately start hitting the F8 key repeatedly until you see the SAFE MODE option. Select Safe Mode and let your system boot up then run AVG in Safe Mode. AVG running in safe mode will not require any intervention from you once it gets started. However it will look a little different to you because the normal GUI Interface will not be there, instead you will have a Black DOS type window running will white letters scrolling as it scans. 99% of the viruses require the Internet Connection to function. As long as the internet connection is active the virus can function, hide and do all sorts of things. Remember you got the virus by some process of being on the internet. SAFE MODE disables the Internet so the virus cannot function or hide. Let AVG seek it out and kill it in SAFE MODE.
Mar 14, 2012 | Computers & Internet
We have an exsisting Access 2003 database. My coworker was given a new computor and now when he trys to use the database he gets the following prompt: "The expression you entered has a function name that...
You are probably missing a private library on the new computer, or have an incomplete installation of Access. Then simple functions like Date() or Trim() don't work, or user defined functions in a private library cannot be found. Your access project probably uses a special library that needs to be copied to the new computer, and it needs to be properly referenced by the Access project.
To see what libraries an Access project has referenced, open any code window (e.g. press Ctrl+G), and choose References from the Tools menu.
If a library is marked MISSING, click the Browse button, and locate the correct file for the library. The table below lists the files for the crucial libraries of your version of Access.
If the library is not even shown, you may need to re-register it. Click the Windows Start button, and choose Run. Enter regsvr32 followed by the full path of the library file. Include quotes if the file name contains spaces, e.g.:
regsvr32 "c:program filescommon filesmicrosoft shareddaodao360.dll"
Occasionally, the problem is not solved until you unregister the library and re-register it. Uncheck the missing library in Access. Close Access. Issue this command, and then the one above to re-register it:
regsvr32 -u "c:program filescommon filesmicrosoft shareddaodao360.dll"
Re-register it (as above). Open Access, and select the library reference again.
May 10, 2010 | Microsoft Office Access 2003 (077-02871)...
Missing DLL files
hi,
http://www.fix-all-dll-errors.com/
Just visit this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
Apr 08, 2010 | West Wood Studios Command and Conquer...
Eltron P210i printhead replacement and aligment
Usually with Eltron and Zebra printers all you have to do is turn the power off, change the print head, turn the power back on and re run your software to get the forms to reload. If you miss any of these steps you will run into trouble.
As long as the labels didn't get moved, it should work once you restart your computer and re run the software you print your labels with.
Aug 12, 2008 | Zebra P210i Thermal Printer
Trying to set the offset on Datamax Prodigy Printer
Add the OFFSET command (Oxxxx) command to beginning of the data. A value of around 0700 usually works.
The prodigy+ does not have any other facility for setting the tear-off position, nor is the effect of the O command persistent.
I don't know where you're seeing that offset value since the printer cannot report it. If it's in your printer driver, then try adjusting the value in the driver itself.
Steve
Jan 07, 2008 | Epson Printer
Always freeze
Firefox will use a lot of disk space over time for temporary use. You might try starting up and run the Disk Utilities program to repair disk permissions.
Dec 25, 2007 | Apple iBook Mac Notebook
Scroll wheel function
You can try using the windows driver for a generic 3 button or wheel mouse. That may require that you go to control panel system hardware and then find your mouse then select update driver and pick one of the generic or microsoft drivers that have the same functions. The problem may show up when you reboot and windows tries to reload the original driver.
Nov 06, 2007 | Logitech Cordless Desktop MX3200 Laser...
Crashing!!!!!!!
First go to recovery console. try this command after the command prompt. CD system32\drivers\ Enter Last line should be: C:\windows\system32\drivers> then... Expand the file from the CD. expand d:\i386\ntfs.in_ or expand d:\i386\ntfs.sy_ if this doesnt work try to run CHKDSK /R. if you get any error while running checkdisk repair you will need a hard drive replacement.
Oct 03, 2007 | Dell Memory Board PE6450 (1409D) Expansion...
IMSI TurboCAD Deluxe 10 for PC Logo
1,123 people viewed this question
Top IMSI Computers & Internet Experts
Hardware and...
Braden Bills
Braden Bills
Level 1 Expert
Are you an IMSI Computer and Internet Expert? Answer questions, earn points and help others
