TOP LOAD WHIRLPOOL WASHER MODEL#LLR6233AWO
WASHER WILL NOT SIN OR AGITATE HELP?
  • 130 Answers
Check the agitator dogs, and the motor coupling
Posted on Jan 26, 2009
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
I have a Whirlpool top load washer model #LSR9434PQO that goes through the cycle but the tub does not spin.
if it does not agitate as well then the drive coupling between the motor and transmission may be broken.
Nov 01, 2010 | Whirlpool LSR9434PQ Top Load Washer
WAsher will not spin or agitate
This is usually caused by the coupler. There is a video showing how to replace at www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool LSR8433K Top Load Washer
I have a kenmore washer model 110.22994. It fills with water but does not agitate. How do I start to identify the problem? The problem started after a friend loaded the machine with heavy jeans.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool / Kenmore service manual for top load, direct drive washers with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing to check is to try the washer on a different cycle.
Then make sure that it will drain and spin.
If it will work on a different cycle, the problem points to the timer.
If it still won't agitate and it WON'T drain or spin the problem points to the Lid Switch
If it will neither agitate, or spin but will drain, the problem points to the Motor Coupler.
Jan 09, 2010 | Kenmore 22982 Top Load Washer
Washing Machine does not agitate
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Following is the Whirlpool installation and maintenance PDF on how top load, direct drive washers work with a troubleshooting section.
Following is the Whirlpool parts list for commercial top load, direct drive washers although the consumer washers are basically the same.
The problem seems to point to the Agitate Cams in the transmission that raise and lower the Agitate gear on the main transmission shaft. These are relatively inexpensive to replace.
I'd also check the splines on the main agitator shaft and the two pronged "washer" on top of it.
Oct 03, 2009 | Kenmore Washing Machines
Won't spin or agitate
replace coupler between motor and transmission
Sep 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator does not agitate unless I add presser downward on the to
There are 3 plastic dogs that have teeth. They become worn smooth and will not engage the agitator. Change these for about $12 and you will be back in business.
Jun 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
LSR7233DQ1
check your lid switch, it can be bypassed until you can get a new one. Just be aware that the machine will agitate and spin with the lid up. To open the top use a putty knife or butter knife at the joint of the top and bottom at the front corners to push the catch in while lifting the top. On an older machine the lid switch goes bad, another thing is the rubber drive part between the motor and the transmission, but the machine probably wouldn't agitate either.
Jul 27, 2008 | Whirlpool LSR7333 Top Load Washer
HOTPOINT WASHER
is the machine a ge or whirlpool , the listing is confused give me the model nunber for help
May 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
569 people viewed this question
Top Washing Machines Experts
