Question about Kenmore 67082 Electric Dryer
Dryer turns itself on & beeps, then off again
Kenmore Oasis Dryer Model #110.67072600 has worked fine. The other night I heard some beeps. Turns out the dryer was turning itself on, beeping one or more times and then turning itself off again. I unplugged it for the night. When I plug it in, it does the same thing. Sometimes I can get the dryer to start, but then it shuts off in a few seconds. Is my control panel fried? The dryer is only 14 months old.
  • 7 more comments
  • Angie Krieg Jul 16, 2007
    OK I get an F2 code. Now what?
  • Angie Krieg Jul 18, 2007
    Thanks so much! When we opened the panel, we found the tech sheet with the info we needed to troubleshoot. Wish I'd thought to look there first. Anyways, we ordered the part today and should have it in a week. All local parts store said the part was backordered.
  • Anonymous May 18, 2008
    Oasis dryer purchased in 3/2006 has similar symptoms. If the dryer does start, it only runs for approx. 90 secs.
  • scottcommerc Jul 24, 2008
    Runs, with a short beep every minute or so. Have had it add minutes to Timed Dry only. (Spooky!) Accessed self-test (THANKS!) and got F2. Next, to tackle the control panel. (Another day) Thanks for the help.
  • law13man Aug 16, 2008
    same thing, get beeps all the time. Did dig and got F2 , So now whet to do. Where is the tech sheet at?
  • steve sicard
    steve sicard Oct 17, 2013
    Mine did similar unplugged came on and beeped 5 hours later. ran self check and came back with no codes. while running it will beep half way through drying and change to cool down some times.
  • Anonymous Mar 12, 2014
    Seems to work just fine just beeps like ten times after it starts a cycle
  • Anonymous Mar 30, 2014
    Dryer keeps beeping while machine is turned off.
  • Anonymous Mar 31, 2014
    my dryer will beep while drying and even after I turn it off and attempt to reset settings
    President:
  • 878 Answers
Aye, see if you can enter the diagnosis mode. What we are looking for is the F-02 code. This will flash when there is a stuck button or user interface problem and only displayed in the test mode. With the unit plugged in and all indicator lights off, select any button except stop. Press for 3 seconds, release for 3 seconds, press for 3 seconds, release for 3 secnds and press for 3 seconds. If you did it right 88 should appear. Press the same button again and if there is a error, it should show up. If no error code shows, open the consol and check the p-5 connector. This will be the interface ribbon to the board. Reseat it and see if the problem stops. Catriver
Posted on Jul 16, 2007
  • Ron Marek
    Ron Marek Jul 17, 2007
    Check with your owners manual and see how long the interface touchpad is warranteed. Sometimes it 2 years from date of purchase. If so call for service. F02, you have a uck or shorted keypad, that's why it's starting on its own. The only other thing you can try is to reseat the keypad harness into the main board. P-5. Catriver.
SOURCE:
F1 code on model# 110.77042600
My amana touch pad started going wacko...beeping constantly....then a F1 message....i unplugged it over night....then it worked for about 2 more days with no problems..then the next day it acted up again...Then i unplugged it again( touch pad only) over night . It has now been 1 month and no problems with it....so maybe before you dish out $$$$...maybe this will work for you also
Jan 03, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Hi I have a kenmore elite oasis dryer. And all of a sudden it only will run for about a minute and then it shuts off. I tried turning it back on again and it does the same thing. Then after the third time...
The first suggestion I have for you is to simply run an Air Fluff cycle with no heat.
If the Air Fluff cycle runs okay then the problem is most likely with the thermistor.
You can try to run the dryer with the vent hose off and see if there is a difference.
Oct 07, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Elite Top Loading Washer with multiple errors
Yes - replace the ECU/Controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis electric dryer beeps and displays code F45
We had this error on our machine for about a year before we finally got sick and tired of it. Our dryer was purchased in 2006.
Here is the solution: the code means there is an error on the thermistor. Our thermistor was loose, as were other electrical wires. My husband tightened up all the connections and the thermistor, and we have never had this error again.
However, we will never buy these machines again either, because we have had numerous other errors on the washer and dryer.
Nov 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
F2 and beeping
The F2 error is the user control board gone south on you, a new board will fix the machine, as always do you own your home and does the insurance cover appliances?
Sep 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis Dryer Model 7704 F 2 Error
after haveing read through some blogs here, the F02 code is either a short in the interface board or the ribbon is loose. I'm having a similiar problem, mine started beeping all by itself, when it was not even turned on, am presently running a load through and is doing fine so far, also, I had unplugged the dryer last night, not sure if that helped but so far is working properly, other advise I read was to make sure the ribbon was seated properly, next step for me will be to do that then order the part (?), sorry I can't be more helpful
Nov 20, 2007 | Dryers
Kenmore 67082 Electric Dryer Logo
3,018 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
