Question about Hoover Washing Machines
Door won't lock optima oph148 hoover - Hoover Washing Machines
  • 6277 Answers
SOURCE: My Hoover Nextra Optima will
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 18, 2011
SOURCE: My hoover washing machine top
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
Posted on Oct 10, 2011
  • 10 Answers
SOURCE: Washer has a door lock when machine is running.
the problem is probaly with the actual door try looking for retailers and see if they will fix the locking mmechnism
Posted on Oct 12, 2011
  • 747 Answers
SOURCE: hoover 1400 door won't close
I would call hoover a service number should be located by the serial number or possibly on the door
Posted on Sep 04, 2012
  • 389 Answers
SOURCE: door won't lock
try pushing the door and hold in if this does not work the door catch is faulty replace internal door lock then should work (common fault)
Posted on Sep 28, 2012
Hoover optima wont lock has new interlock
take clip of door seal to access the doorlock then it should be easy to change when you take the screws out of the lock from the front of the machine
Feb 05, 2014 | Washing Machines
Hoover Auto Washer 1000 A2100
Sounds like faulty door lock
Jun 19, 2013 | Washing Machines
Drivers side door won't open on Kia Optima 2006. All other doors unlock and open, Can't open the drivers side door from the inside either. Any suggestions?
I have this same issue,I'm told other kia's also have this issue. Friend of mmine says little pin/rod that goes from lock 2 handle needs adjusting,don't know.have body shop check it out 4 u or call kia.I'm sure they have heard of this problem.That's what i'm gonna do if I can get mine running,been down 4 about 2 wks. good luck
Feb 08, 2013 | 2006 Kia Optima
Hoover 1400 door won't close
Sep 04, 2012 | Washing Machines
Hoover oph 148 stopped working through a cycle
I just had a similar problem to this with my Hoover OPH148 washing machine. The Cold Wash LED would flash 14 times repetitively after each wash cycle. The only way to open the door was to turn the controller to the off position.
I checked the heater element with a continuity test and found that the heater element had burnt out.
Hopefully this will help someone else if they see the same condition.
Jul 18, 2012 | Washing Machines
Hi Have got a hoover optima about 18 months old. Has got an E02 message in the middle of a cycle because the water board have turned the water off without telling anyone. Can't open the door or get...
'E02' for your Hoover Optima states 'fill time-out' which is not surprising considering that the water board turned the water off!
I hope by now that the water is back on and so is your washer ;-0)
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jul 27, 2011 | Hoover Washing Machines
Manual for optima 616 hoover
Hoover optima 6 kg. When I close the door it clicks shut as usual but the door security light is flashing and it wont come on. Please help.
Aug 02, 2010 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
