Question about Plumbing
Replace kindred pull out faucet hose - Plumbing
3 Suggested Answers
  • 112 Answers
SOURCE: We are trying to replace a Grohe kitchen pull out
The universal hose will not work on certain model faucets,best bet contact manufacturer and they may provide you a new hose at little or no cost if you tell them you will put a different brand faucet in.
Posted on Jun 12, 2011
Testimonial: "Thanks, that is something I didn't consider. After much wrangling, he did get it loose and re-threaded it. It seems OK for now. Thank you for replyi"
headstrong56
  • 493 Answers
SOURCE: replacing pull out hose on kitchen faucet
get a hole saw that fits a drill. they come in all sorts of sizes
Posted on Jul 16, 2012
How do I replace the hose on a rohl 3810 faucet pullout pray head faucet
contact ROHL customer Service, request a new hose (part number R45158), detach the end on the underside with a wrench and pull it out. Insert new hose through the topside guide neck and reconnect on the bottom connection.
Nov 02, 2013 | Rohl R77V3SPN Country Pull-Out Bar Faucet...
Replacing pull out hose on kitchen faucet
Jul 16, 2012 | Danze Plumbing
We are trying to replace a Grohe kitchen pull out faucet hose. My husband bought an Ace universal pull-out hose which is now stuck (husband tried to thread it through the faucet opening.) Does anyone...
Jun 12, 2011 | Grohe Plumbing
How do I remove the cartridge?
most single handle styles have a crown nut or collor ..allen screw under handle 1st 1/8 allen , then wiggle cartridge . upward ..shut off watter 1st good luck';';'
Mar 24, 2011 | Kindred Brush Nickel Single Handle Kitchen...
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
Can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
Jul 13, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe ladylux plus kitchen faucet leaks from multiple points along metal pull out hose attached to faucet head. Is this fixed by replacement of same hose? How do I replace the hose?
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Feb 23, 2010 | Grohe Plumbing
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
