Question about Bernina 1008
Bernina 1008 feed dog problem.
Help!
I have a Bernina 1008 and am having problems lowering the feed dog to free machine/embroider.
I have tried numerous times to turn the dial on the front of my machine to lower the feed dog and nothing seems to happen.
Is there another way to lower the feed dog without the dial?
  • 202 Answers
Your machine needs oiling. The feeddogs are stuck. Could be in several places. You would have to remove the back and side covers to get to what needs cleaning and oiling. Especially behind that knob. Just removing the covers is a job so I can't recommend you do this unless your trained. But you can try. Don't forget the screws beneith the machine. But really, there is too much behind the handwheel for a novice to deal with. Maybe see if you can just let some sewing machine oil just run down behind the feedog knob and work it alot.
Good luck.
Posted on Feb 07, 2009
How do I lower and raise dogs on the bernina 1008
unless there is a mechanical failure , the feed dogs are governed by the forward/reverse control
if it is in neutral position then the dogs will not move
Oct 27, 2015 | Bernina Sewing Machines
Bernina feed dog down and will not return to normal position by switch
1. Clean and lubricate entire machine following the MANUAL instructions.
2. Try to "lower" it again then try to raise it - several times.
If this does not solve it, see a service person.
Jul 08, 2014 | Bernina 1008
Feed-dog problem with Bernina 1008
Immediately take it back where it was serviced. They did not do a thorough job!
Apr 19, 2017 | Sewing Machines
Error message asking to lower feed dogs before embroidering, feed dogs were lowered
Try raising and lowering the feed dogs a couple times there may be something in there that's tripping the sensor.
Nov 11, 2012 | Janome Memory Craft 10000
I need to raise the teeth on a Bernina sewing machine and I can't remember how to do it. Any help?
On the front of your machine, is there a knob that you turn for zig-zag/straight stiching and the other way for darning? There will be an icon showing the stitches
The darning selection will lower the feed dogs.
Apr 30, 2010 | Bernina 1008
I would like to set my bernina 1008 to a freehand setting but d not have the manal i would like ot know what control to have on which setting to make this work
You have to lower the feed dogs and use a darning foot. Use straight stitch setting.
If you cannot lower the feed dogs, this model may use a cover plate.
You can also set the stitch length to zero and tape an index card over the feed dogs with a small opening for the needle.
You will be controlling the stitch length as you move the fabric by hand.
Mar 01, 2010 | Bernina 1008
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Fabric not advancing
Could be as simple as pushing the button that raises and lowers the feeddogs for free motion.
Aug 25, 2007 | Bernina 1008
Fabric doesn't advance
Have you checked your feed dog position? The fabric will not advance if the feed dogs are in the down position. For the machines which don't have the raise/lower feed dog capability, there is a plate that covers the feed dogs and must be removed to advance the fabric when sewing.
Nov 06, 2006 | Bernina 1008
Sewing Machines Logo
1,111 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
