Question about HP Photosmart D5360 InkJet Printer
Print cartridge missing or not detected hp photosmart d5363
worldvet
  • 859 Answers
SOURCE: My HP photosmart C4200 ALL-in-One
Below is a partial entry of the help document at HP. The complete text can be found by clicking on this link here.
If you have already read and completed these steps, please notify me that you have by using the Text Area Comment Box below. Proivde me with any thing else you have already tried. Lastly, do you have a manual for your printer in digital format that you can place on your PC and refer to? I can post one here for you if you need it.
Essentially, there is no easy Trick to clearing this issue. The most common error made by users it in replacing both cartridges at the same time. Each cartridge should be replaced individually. Once completed the printer will want to execute a print head alignment test. This print out will include instructions on selecting the numbered lines that line up most exactly. Then you would enter the corresponding number.
Bypassing or interrupting this alignment test after replacing cartridges will cause error messages such as yours. So, if you did this out of ignorance or confusion, remove each cartridge one at a time using the method descrbed below. When both have been removed and reinstalled and the alignment process completed you should be error free. Should you still receive this error, remove and clean each cartridge using the method described below, one cartridge at a time.
If after completing all the steps below, you still receive the error message, your printer has a larger problem that is internal hardware related. You can either replace the printer or have it serviced by HP. Most people opt to replace the printer as an error such as this at the internal hardware level usually indicates that the printer has reached the end of its usable life span. If this is happening prematurely, have it serviced under warranty. Printer warranties are usually one year from HP. If you purchased using a credit card you may have an extended warranty. Check with your card company right away for information on any extended warranty you have from using your Credit Card.
If you have any further questions, please ask me using the comment box below.
Regards,
Worldvet
Solution one: Remove and reinsert the ink cartridges
  1. Turn the product on.
  2. Make sure to have letter or A4 unused, plain, white paper loaded in the input tray.
  3. Open the ink cartridge door.
    NOTE: Make sure that the carriage holding the ink cartridge moves to the right. If it does not move to the right, turn the product off. If it is a new product, make sure all the packaging material is removed. Close the ink cartridge door and then turn the product on again. The carriage should move to the right. Figure 1: Opening the ink cartridge door c01333689.jpg CAUTION: The product must be turned on before the ink cartridge door is opened. If the product is off when the ink cartridge door is opened for access to the ink cartridges, the product will not release the cartridges. The product can be damaged if the ink cartridges are not docked safely before removal.
  4. Wait until the carriage is idle and silent, and then lightly press down on an ink cartridge to release it. The error message should indicate the problem cartridge by displaying an icon that represents it.
    • The tri-color ink cartridge is in the slot on the left.
    • The black or photo ink cartridge is in the slot on the right.
    Figure 2: Pressing down on an ink cartridge to release it c01333690.jpg 1 - Ink cartridge slot for the tri-color print cartridge 2 - Ink cartridge slot for the black and photo ink cartridges
  5. Pull the ink cartridge toward you out of its slot.
  6. Make sure the tape has been removed from the cartridge. If the tape has not been removed, remove it now. Figure 3: Removing the tape c00880894.jpg CAUTION: Do not touch the copper-colored contacts or reattach the tape.
  7. Hold the cartridge with the HP logo on top.
  8. Reinsert the ink cartridge into its slot by gently pushing the upper part of the ink cartridge forward until it clicks into the socket. CAUTION: When installing the ink cartridge, do not rest your hand on top of the product for leverage. This might cause the carriage to lift out of position. Figure 4: Incorrectly grasping the top of the product for leverage c01333691.jpg Figure 5: Pushing the cartridge in firmly c00853118.jpg
    • When installing the tri-color ink cartridge, slide it into the left slot.
    • When installing a black, photo, or gray photo ink cartridge, slide it into the right slot.
    Figure 6: Tri-color cartridge in the left cartridge slot and black cartridge in the right cartridge slot c00880896.jpg
  9. Close the ink cartridge door.
If the error message persists, continue to the next solution.
Posted on Nov 11, 2008
  • 4 Answers
SOURCE: printer says 'cartridges missing or not detected'
Did you run the print sample page used to align the print cartridges by scanning the test page?
gary.schaut@gmail.com
Posted on Jan 12, 2009
  • 83 Answers
SOURCE: HP Photosmart C4585 printer says print cartidges
Try to verify if it recognises the catridges you have. If not, clean the contact pins and try to fix it again.
Posted on Jan 13, 2010
michaelshaun
  • 126 Answers
SOURCE: I HAVE A HP PHOTOSMART C4580 ALL IN ONE PRINTER
please follow the onscreen instructuions from the below mentioned URL and hopefully this should fix the problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&cc=us&lc=en&dlc=en&product=3418707
If still your problem is resolved please follow the below instruction
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672980&cc=us&lc=en&dlc=en&product=3418707
hope this should resolved your problem if not then call
HP toll free number 1800-474-6836 they will change the printer if the warrenty period is there.
hope your issue gets resolved
thanks
regards
hamid
Posted on Feb 25, 2010
SOURCE: HP Photosmart C4580 Print cartridge(s) missing
This error message usually happen if the cartridge is not properly seated or the copper-colored electrical contacts have problem. Check this website for proper cleaning and installing ink cartridge.
If the problem is resolve try replacing the ink cartridges.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01442936&lc=en&dlc=en&cc=us&lang=en&product=3418707#N68
TNX
Posted on Apr 24, 2011
I have installed colour cartridge 351XL and black 350 cartridge but my printer still says Print cartridges missing or not detected
Have you removed the shipping tape from the print cartridge? It covers the print head on the cartridge to protect them so they won't leak ink.
Nov 01, 2010 | HP Photosmart C4280 Aio Printer
HP printer says cartridges missing or not detected
Try to uninstall the software and reinstall but only the custom drivers for printing an any updated for them.
Apr 29, 2010 | HP Photosmart C4180 All-In-One InkJet...
HP Photosmart displays a message saying "Printer Cartridge(s) missing or not detected" though I've just put a new cartridge into the machine. How do I fix this so I can print again?
Remove the cartridge.
Make sure that you removed a piece of clear plastic tape that covers the ink-jets. It's placed there to prevent the ink from drying-out while the cartridge has been sitting on the shelf at the computer store.
Re-insert the cartridge, and be sure that it "clicks" into place.
Apr 02, 2010 | HP Photosmart C4280 Aio Printer
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Print cartridges missing or not detected message
I tried to solve this problem but still persist
Mar 22, 2010 | HP Photosmart C4280 Aio Printer
'Print cartridge missing or not detected' Message
You better buy a new printer.Probably you have a problem in carriage unit on your printer.
Oct 05, 2009 | HP Photosmart C4280 Aio Printer
Printer says 'cartridges missing or not detected'
Jan 05, 2009 | HP Photosmart C4280 Aio Printer
HP Photosmart D5360 InkJet Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
