Question about APC Back-UPS 650MI (BK650MI) UPS System
Ups 650MI when connected to the power it produce sound
My ups produce sound when connected what can i service it.
    Scholar:
  • 64 Answers
Too small, too cheap..., not cost effective to fix. Cheaper to replace, and I suggest you might go bigger.
www.storminprotection.com
Posted on Sep 08, 2009
My whirlpool white magic 650 P produces contineous beep sound while connected to the electric plug. However the power switch and light indicators on the mechine is not working.
Sounds like you have a control logic issue. Either a button on the control panel is stuck, or the control board is defective. Find the model number on the unit and post it in the comments please.
Jan 11, 2015 | Whirlpool Washing Machines
My technics new class a wont produce any sound
does the power amp have any speaker buttons? did you press one, from the group with no speakers connected?. Are the speaker cables still connected? think what happened before you lost the sound. There could be the cause.
Nov 04, 2014 | Audio Players & Recorders
My laptop is not switching it just lights up the battery led when i put in the adapter.and it produces some sound where you connect the adapter
Remove main battery and try again, if no! sub out the ram memory one at a time and test each, if nothing! remove the hard drive and power up, remove CD/DVD drive and finally the wireless card, if none of these work! the motherboard has major issues.
Apr 22, 2012 | Computers & Internet
APC UPS BK650MI Transistor F1010E Burnt
It will be cheaper to replace the UPS. You will spend more time and effort then it's worth.
Sep 13, 2011 | APC Back-UPS 650MI (BK650MI) UPS System
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Do we need an amplifier to connect home theater yamaha nsc150/e105 with TV, DVD, PC.plz explain
Yes, you need an amplifier, since the "levels" of the sound-output from each device (TV, CD-player, cassette-player, Sony mini-disk player, turntable) are not sufficient to physically move the "cones" inside your speakers, to push air around, to produce sounds.
You need "watts" of power to push air, while the devices produce milli-watts (watts/1000) of power.
Also, the amplifier is also a "decoder", electronically processing the input to produce "5-channel" (left, front, right, back-left, back-right) surround-sound output.
Sep 30, 2010 | Audio Players & Recorders
Gererator stops producing power
This sounds like a "flying open" in the rotor. Over time a small part of the wire that winds around the rotor has gotten cracked just enough to open up when it's warm and being pulled on by the force of the rotor spinning. To test this further, take the wires off the brushes and connect an ohm meter across them then run the generator, if you see the ohm meter indicate an open circuit you've found the problem. This can be repaired but it means removing the rotor and finding the weak spot in the winding. You could replace the rotor for a couple of hundred dollars or get a new generator.
Regards,
Carl
Feb 23, 2009 | Coleman Powermate Premium Plus 6250W...
Buzzing/vibration noise from ONYKO TX-SR506 unit
If the unit is under warranty, DO NOT open it up. Bring it in for an exchange or warranty service. Explain that the unit makes noise during use and it will be serviced. This could be as simple as a bad connection in the power supply area and you are hearing oscillations or it could be a defective power transformer. Either case will be covered under warranty so there should be no charge to you.
Keep us posted.
Dan
Feb 17, 2009 | Onkyo TX-SR506 Receiver
Canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
Dec 03, 2008 | Office Equipment & Supplies
Amp powers on, but no sound is produced
a failed volume control potentiometer? it's possible.
Jun 04, 2007 | Sherwood RD-6108 Receiver
APC Back-UPS 650MI (BK650MI) UPS System Logo
119 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
