Question about Optoma Office Equipment & Supplies
Can you mount projector sideways to a wall - Optoma Office Equipment & Supplies
3 Suggested Answers
  • 8909 Answers
SOURCE: Does this Dell projector rotate
It is not recomended to mount it sideways as the air flow will be restricted and the picture will not rotate 90 degrees.
Hope that helps.
Posted on Mar 01, 2011
Testimonial: "thanks. what i needed to know."
heathgr
  • 442 Answers
SOURCE: hi. I just purchased a used
MENU, MAIN , MIRROR and select the orientation you need
Posted on Apr 08, 2011
I need screen
Is it for your projector. Contact any one of the dealers of LCD or DLP projectors in your area. For Projector Map type, Wall mount, Stand with screen, Motorised Screens are available.
Nov 09, 2015 | Televison & Video
Does this Dell projector rotate the image? say,... if i wanted to wall mount it sideways. thanks
Hope that helps.
Mar 01, 2011 | Dell 2300MP DLP Projector Multimedia...
We have Toshiba MT200 projector mounted on wall with unit inverted. My question is how do you flip the image 180 degrees on the unit?
use the onboard menu on the projector it should have the option for this just check through it completely :) hope this helps
Feb 25, 2011 | Toshiba TDP-MT200 Multimedia Projector
Can the Optoma EP739 be ceiling mounted and projected upside down? what are the steps to do so? also, what would be the best mount for said projector?
Mine has been in place for about three years. Because the ceiling was open I was able to create a connection for a tripod head on the ceiling and then using a STRONG tripod head and some small bolts (longer than the originals) I mounted an external base and with the tripod head fitting dttached to the projector it just became a matter of running the various connector cables from the sources I use that require projection to my wall.
Dec 02, 2010 | Optoma EP739 Multimedia Projector
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
Dec 22, 2009 | Acer P3250 DLP Projector
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
Wall mount Akai LCT 3285TA flat panel TV
You have to get correct wall mount for this model tv.
Sep 28, 2008 | Akai LCT3285TA 32 in. LCD Television
Projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Nov 12, 2007 | Mitsubishi XL8U Multimedia Projector
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
