Question about JVC AV-32950 TV
JVC flat screen digital freeze
After 40 minutes the digital picture freezes and looks slighly snowy. The analogue reception is fine. Switch off for a while and it works for another 40 minutes.
  • michaeljdarc Jan 26, 2009
    no not cable. Its definately not the signal becasue other TVs are ok. Reckon its the TV heating up and blowing a circuit maybe then cooling down
Digital board needs replaced...very common issue.
Posted on Nov 02, 2012
    Problem Solver:
  • 6 Answers
What do you have running you cable
Posted on Jan 26, 2009
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
Nov 14, 2013 | Televison & Video
I have an LG 32LT35 LCD T/V that keeps freezing when on Digital, but I get excellent reception on Analogue. I have another LCD T/V to the same aerial connections and get excellent No-Problem reception on...
You mention you have tried a digi box and it made no difference. If on the same aerial point, it will be the aerial. Check the cable as there may be a "ghost" on the digital frequency causing errors and picture freezing.
Mar 08, 2011 | Televison & Video
Color went in and out, no i only get fair black and white picture often grainy
I'm assuming here that this tv is being used for analogue reception because on digital you either get a perfect picture or when the signal is weak enough, nothing at all (common when trying to use rabbits ears or in poor reception areas). Assuming analogue then, when the signal is weak (grainy or snowy picture) the colour (called chroma) is automatically turned off because grainy colour is unwatchable. This is normal. Solution, a better aerial to provide a stronger signal.
Jan 20, 2011 | Akai PDP4206EM Television
Tv stays on standby when switched on, then switches itself off after a minute or 2. Then may show a picture after several attempts to turn on, but will turn off again after a few minutes. It does...
I would suspect this has issues with the power supply, I would put it down to faulty capacitors, take the back off and look on the power supply for domed shaped capacitors, they may also leak a brown liquid like substance.
Replace these and all should be ok if it is capacitor related.
Mar 05, 2010 | Televison & Video
I have just moved house to Reading and previously was able to view freeview tv using my old indoor aerial in my 2nd floor flat in london. This indoor aerial didn't pick up any signals, not even analogue,...
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
46 Picture issues.
The Digital bd has gone bad and needs to be replaced. Part# is BP94-02065A
Jul 09, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
Snowy reception on TV with LG DVB418
have you got both cables going into your video ?? if not you need a video splitter to input both the digital and analogue aerials then have a coaxial cable going to the tv
Mar 08, 2009 | LG DVB418 DVD Player
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
2 year old Samsung 50" DLP
Sounds like a bad digital board to me. Not too hard to replace in those models but, you do have to write down a few settings before replacing it. These settings are available in the service menu. Any questions let me know tvtek@msn.com
Nov 30, 2007 | Samsung HLN617W 61" Rear Projection HDTV
JVC AV-32950 TV Logo
171 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
