Question about KDS Valiant 6380iPTD-01 Notebook
Vaillant boiler that supports a time switch 110
I cant seem to be able to sort out this boiler,i'm in a rent house but the boiler has no manual. it keeps going off and i can't get it to work again, its really doing me head in. please could u help me.
thanxs michelle
  • 6 Answers
Vaillant time switch 110 have always been problematic. Dry joints on circuit board and faulty clocks.
They seem to last from 2 months to 3 years but can be bought for £33.70 inc VAT from https://supreme1.sslpowered.com/cgi-bin/DMdatabase.cgi?action=/mnt/w0502/d01/s11/b009fa92/cgi-bin/home/Shop/Boiler_Accessories/Vaillant.txt&item=00038
Hope this helps
Posted on May 26, 2011
Vaillant boiler leaking only when heating switched off.
It would seem a joint has come a bit loose from the heating and cooling cycle. put a drip pan under the leaking area( the drips would evaporate quickly), then next time you shut it down go through all the joints in the area with wrenches to find the loose joint.
Oct 27, 2014 | Water Heaters
Manual for Vaillant turbo Max combination boiler
No model listed, but this manual covers 8 of the most popular models.
Boiler Instruction Manual
May 04, 2014 | Computers & Internet
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
A have a vaillant ecotec boiler and when it fires up the fan is very noisy is this right
most likely no. there might be a obstruction in the blades, dirty filter, the motor might have a bad berring , the fan blades might have bent and now are touching the housing prob should call a trained tech boilers aint no joke
Aug 06, 2011 | Heating & Cooling
I have a Vaillant Time Switch 110 and for the last week or so the overflow pipe has been pouring water out. I have had the boiler turned off hence no hot water or central heating for the last week but it...
Your pressure relief valve is probably bad, replace it. You might want to tap on the expansion tank to see if that is empty. If it is full, replace it.
Mar 07, 2011 | Heating & Cooling
Our vaillant atmo TEC pro seems to have a faulty
Sounds like your thermalcouple may be failing, replace that
Nov 23, 2009 | Home
Lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Oct 10, 2009 | Water Heaters
I have a Vaillant boiler Turbo Max VUW 242/1E, central heating is working but no hot water
You have a faulty diverter valve, this is a fiddly job, you need to call in a 'Gas Safe' engineer to diagnose and replace this
I hope this helps
Steve
Jun 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Nov 04, 2007 | KDS Valiant 6380iPTD-01 Notebook
KDS Valiant 6380iPTD-01 Notebook Logo
2,033 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
