Question about Kitchen Appliances - Others
How to reset a maygay fruit machine
Display screen is saying MEM RESET ALM
  • 46 Answers
SOURCE: alm one
PDAs that use touch screens have a very thin membrane over the screen itself that responds to pressure. If this membrane becomes damaged, which it sounds like what has happened, then you're more than likely going to need to have it replaced. You can try doing it yourself, but it's WAY up on the difficulty factor because of the complexity of the connection to the circuit board on the Tungsten E2.
To determine if your unit is, in fact, actually damaged, you should first make sure that you've syncronized the unit (which may not be possible if you don't have it set to automatically activate HotSync when the device is attached) then do a "hard reset" to restore it to the factory default. To do this, hold the reset button while simultaneously holding the power button for, at least, three seconds. You will get a message asking you to press up on the control pad to reset to factory defaults. Once the unit is reset, try the screen again... touching even the outer areas to see if there's any response. If it reacts, or beeps at all, then it may be an issue of recalibrating (using the "Digitizer") once it's fully reset. If not, it will need repair/replacement.
Posted on Nov 09, 2007
  • 52 Answers
SOURCE: Credit and Bank screen (fruit machine)
Is this a slot machine?
Open the slot door and check the connections behing the display board. Make sure theres no pinched wires, and everythings plugged in tight.
Posted on Feb 15, 2009
  • 10 Answers
SOURCE: changed mem speed lower then got a beep and black screen
Reset the BIOS.
Plan A: Look in your motherboard manual and find the location of a "CMOS Reset" jumper. Move the jumper from its current position to its other configuration for five seconds. Then, put it back the way it was and turn it on. If that doesn't work use Plan B :)
Plan B: Take the clock battery out, and short (touch) the battery holder metal contacts with a switch. Put the battery back in. Turn it on and see if it works.
All your BIOS settings will be reset to default after this, including your clock.
Posted on May 15, 2009
mhkamran
  • 180 Answers
SOURCE: AT MACHINE TURN ON DISPLAYS UNDER HIGH PRESSURE
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just check the following :- 1# Verify the ISV tank is not overfilled.if full,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid & High pressure switch for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Posted on Jul 14, 2010
  • 11 Answers
SOURCE: i have a maygay fight night fruit machine and it
whats the name of the manufacture?! the problem will be the hopper, its more likely that it isnt broken, probably just a pound coin jammed up inside it,
Posted on Dec 03, 2010
Do I need a reset key to reset my global pub fruit machine
First! What is a "Global Pub Fruit Machine"? I'm thinking it is a world-wide machine that dispenses fruit inside a bar or pub?! Sorry,. IDK what you mean! Is this a Joke? I need (A LITTLE) more info. Please
Oct 19, 2014 | Office Equipment & Supplies
I recently brought A fruit machine from my local football club, my problem is that when I turn it on by the main plug socket, I get no lights come on at all and theres a high pitch buzzing sound comin
A What? At a What? A Fruit Machine at a Pub? This is the 2nd question about these "Fruit Machines!" First, buy a Fruit Machine from a Fruit Store! Not a Pub! That's Like Buying a Car from a Mortician! It's going to be Dead! LOL. Why does a Pub, Sell Fruit? I don't get it? I need more info here Mate!?
Oct 19, 2014 | Televison & Video
Fruit machine
HI Give me GTA IV password key pls!
Jul 16, 2013 | Video Game Consoles & Games
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
I have a maygay fight night fruit machine and it wont pay out what is it that needs fixing on it to pay out
Nov 28, 2010 | Digital Illusions Software Ultimate Fruit...
Maygay simpsons moes tavern fruit machine nothing lighting up seems to be power though help please
your lamp driver board has gone im afriad, you mite be able to ring the maunfacture and order a new one, once you have it in your hand its not hard to fit, hope this helps, tom
Sep 13, 2010 | Computers & Internet
Need to set time on WalMart TGHK watch.
If its digital that makes it more difficult to give setting directions online. Need to know the exact model #. I would do a google search to try and find your watch and you might find a manual online. OR you could seek out a local watch repair business and they should be able to set it with no problems. Most Sears have a watch repair kiosk in their stores! I woudlnt take it back to Walmart because they are just sales people! They have limited watch knowledge!
Jan 09, 2010 | Watches
The Screen displays random lines and numbers.
Clear the screen. Reset RAM :[2nd][MEM][7:Reset][All ram] [2:Yes] Ram cleared is displayed. [Clear] the screen.
Hope it helps.
Sep 19, 2009 | Texas Instruments Office Equipment &...
I can't reset my Atomic Traveling Alarm Clock C17DD2090(WIC#6930
First, make sure you have new batteries in it. Then you have two choices:
Hold down the 3rd button -- the antenna button -- until the little antenna sign displayed on the right starts blinking and "broadcasting"...and then wait for the clock to set itself.
When that doesn't work (LOL), try this:
Hold down the "Set" button until each of the various fields start blinking. Then press the up button (3rd one) or the down button (4th one) to adjust each field to the desired number, etc. At least, that's what my office technician did to set mine. Good luck.
Mar 25, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
Kitchen Appliances - Others Logo
46 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
