Question about Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952
How do you reset kenmore 500 washing machine model 29522801
5 Suggested Answers
  • 949 Answers
SOURCE: kenmore top loading washing machine model 4021092, keeps filling
It is most likely siphoning out. Here is a link that will help explain it and how to correct the problem, let me know if this helps. Thanks
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
Posted on May 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore 80 washing machine
Inside your control panel - there is a service manual. Wiring information is in the service manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore, Elite Wash machine control lock light on. how to reset
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 17, 2010
machinetech7
  • 1344 Answers
SOURCE: kenmore 500 washer Water fills up, then starts leaking out the bottom of machine.
Its possible that the motor is bad but that possibility is at the lower end of the list. You can check this by this method. 1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. Further more in some of the newer models you have to take a thin paint scraper and slide under the left and right normers to press the clips in to release. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off. 7) get a jumper wire and find the block that you disconnected that wasn't attached to the caseand place the jumper where in the holes where the is a wire other than green, which is ground. This is for later on. 8) Now directly at the bottom center area you;ll see a plastic box looking thing with two hoses connected to it. Thats the pump. Its held on by two clips.Remove the pump. 9) being careful, plug the machine in and let in fill, with the pump off but the hoses still connected to it. When it reaches the agitate part of the motor starts working then something is caught in the pump. Empty the water so you don't flood the area, take the hoses off and remove obstruction. If the motor still hums leave the water in, unplug the machine, and move to next step. 10) The motor is held on by two clips as well except these are screwed to the motor with two quarter inch screws. Remove the screws, pop the clips then take the motor off. You'll notice on the back side a piece of plastic with three prongs. Thats the motor coupling. Plug the washer back in and turn it on, if the motor shaft turns the transmission is locked up, if not the motor is bad. I mention the motor coupling because to put its actually three pieces, one peice that looks like the one on the motor a rubber thing that has six holes, one for each leg of the coupling. You'll have to line that up to get the motor back on. Well, hope this hwlps, good luck.
Posted on May 29, 2012
Kenmore top loader mod. 110 29522801 does not run after filling with water. The lid switch could be bad. Are there other problems that should be addressed?
if the unit is filling with water it is not the lid switch because it will not fill with water if the lid is open
problem areas are the water level switch is not energizing the wash cycle as well as switching off the incoming water
if it is stopping the water but nothing else , have a technician check the program board
Jan 13, 2017 | Kenmore Washing Machines
I have a Kenmore 500 series top loader and after I do a cycle with bleach it will still get bleach on next load. Why is that?
ou are best run a quick wash on an empty machine after using bleach there is always water left in machine
Oct 14, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
Kenmore 500 3.5 cu. ft. Top-Load Washing Machine 2952 Logo
219 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
