Question about Vizio L15 Television
My vizio gv52l fhdtv10 hdmi inputs don't work
SOURCE: green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Posted on Jan 09, 2008
jomabug76
  • 1148 Answers
SOURCE: External input sources won't receive signal
UNPLUG THE HDMI AND TRY,,
Posted on May 15, 2009
gsalmen
  • 77 Answers
SOURCE: Are any of the 50
i think they used lg or samsung screens, you will have to open it up to see the screen model number
Posted on Jul 09, 2009
  • 8457 Answers
SOURCE: hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Posted on Aug 17, 2009
  • 8457 Answers
SOURCE: Vizio gv42L working fine on cable hooked directly.
Reset to factory setting,should work,back to normal,not than ur backlight video board is dying shorting out.
Posted on Dec 22, 2009
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
Vizio E420vt works on all inputs EXCEPT the (4) HDMI inputs which seem to be dead. What to try?
The main board will need to be replaced or repaired. There is a HDMI receiver chip on the board that has been damaged by a surge or static.The part can be replaced but requires very fine detail soldering skills.
Jul 13, 2016 | Vizio Televison & Video
My Connections From VIZIO 1080P & Laptop using HDMI But Is Not Working
If the firmware to HDMI is not installed, there will be no HDMI reception, although all the other inputs are OK. Contact the authorized service center. Software upgrade/re-install is a skilled work.
Jun 09, 2014 | Vizio 47 120Hz 1080P Full HD LCD HDTV
Problem with Vizio SV421XVT
I am also having the same symptoms for my SV421XVT. TV works great except all HDMI ports are not receiving signal. Devices work through the AV Ports, and TV reception is fine. New Roku box is also not working through HDMI but works with AV. Wish I had a solution to this.
On a another forum for another TV it was suggested that boards need to be replaced. I hope I can get these boards for a reasonable cost.
Aug 16, 2012 | Vizio SV421XVT 42 in. LCD TV
I PURCHASED A MAGNAVOX Z V 427MG9 A VHS DVD RECORDER.I HAVE A NEW VIZIO VW26L HDTV. HOW DO I CONNECT THEM? I HAVE ALREADY CONNECTED A HDMI CABLE TO IT BUT DON'T KNOW TO SET IT UP. DO I NEED ANY OTHER...
HDMI cables are actually wonderfully simple to connect. Once you have connected one end to the TV and one end to the DVD player, you will simply need to change your input channel using your TV's remote. Find a Input or Video source button and press it until the screen says HDMI. Now your TV may have several HDMI ports so you may have to try a couple HDMI channels before you find the right one.
Hope that helps!
Jul 19, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
I am looking for a used Vizio GV52L stand anyone has one that wants to sell. thanks,
Look on Shopjimmy.com or try EBay under Electronics TV/Parts
Encompass Parts Might have them in stock 1-800-638-3328
Mats Electronics 1-800-628-1118
MCM 1-800-543-4330
Jun 23, 2011 | Vizio P2 42 in. HD-Ready Plasma Television
Hi I have a 32 inch hd vizio tv and a ps3 system and I bought s Belkin hdmi audio and video cable and I'm trying to figure out how connect the cable to the tv and ps3 to get hd channels and hd games and...
Cable: First you need to be using an HD Cable box to get the HD channels that your provider offers. if you don't, you can't get HD channels. Keep in mind that not all of the channels that your provider offers are in HD. Out of the 300+ channels that my provider Cox Communications in Las Vegas offers, they offer 91 of them in HD. If you have an HD box, you need to go into the settings menu and make sure that your video output is set to constant as you do not want it bouncing between different resolutions when you change channels. In your case you will have two options, 720p and 1080i (1080p does not exist for cable due to the amount of bandwidth required). Choose 720p because your set is under 40" and you won't see a a difference between 720p and 1080i except for that because it's progressive, HD may actually look better. (NOTE: although your analog channels will display at 720p, they are not in HD. They are simply up converted SD so don't expect that they will look like HD channels.) Also be sure to set your audio settings on your box to "HDMI out."
In general, HDMI devices should automatically detect HDMI input but since I don't know what kind of box you are using, it is possible that HDMI-out is disabled in the settings. My box (Scientific Atlanta) doesn't have that option, but I don't know about others. As far as the set is concerned, plug the HDMI cable into the input you want to use (if it's a new Vizio, I'm assuming there are three inputs as that's what my 32" Vizio in the kids' room has) and the set will auto-detect the HDMI input and automatically set the resolution accordingly.
SIDE NOTE: The only other way you're going to get HD channels from cable without a box is if you're using your COAX cable directly in to the TV and that is only if your cable provider has them floating on the line and you're only going to get the 5 major networks and Univision in HD.
PS3: This is even easier. WIth your PS3 powered off and your TV powered on, connect one end of your HDMI cable to the HDMI out on the PS3 and the other end to the appropriate HDMI input on your TV (of your choosing). Power on your PS3. Your TV will automatically detect the HDMI input from the PS3 and put that HDMI input on the screen. You will get an on-screen message from the PS3 detecting HDMI and it will ask you if you want o use HDMI or words to that effect (I can't remember the exact message... it's been a while). Choose "yes" and it will adjust the picture accordingly and should automatically choose the highest video resolution your television can display. To verify your settings, first hit the "guide" button on your Vizio remote control and in the upper right corner it will tell you at exactly what resolution it is displaying at. If it's not where you want it to be, on your PS3, go the Settings Menu and scroll down to "Display Settings" and the first item on the list is "Video Output Settings." Follow the step by step on screen menu prompts to determine your display settings, and choose "automatic" when prompted. If everything is copasedic, the highest resolution your television can display at will be listed at the top (and will be the current setting) and all of the other resolutions will be listed below it. If something is wrong between the "handshake" between the HDMI from the PS3 to the TV and it doesn't display in HD, go back into Video Output Settings" and when prompted, choose manual in stead and set the resolution on the PS3 the highest your TV can display. NOTE: Most 32" TV's have a maximum resolution of 720p fir the reasons I stated earlier. Check your manual for the specifics on yours. Furthermore, all PS3 games are in 720p so even if you have a 1080p TV, don't expect higher resolutions than that. AS far as Netflix is concerned, not all of their programming is in HD. The scale for Netflix is SD/Low/Medium/High/X-High. HD/Low/Medium/High/X-High, your quality depends on the program and strength of your Internet connection.
Closing: I'm a little confused by your issue as HDMI is automatic and you should automatically be getting HD so the only other thing I can think of is that your display needs calibrating and you just think you aren't getting HD. In order to get the most out of your new TV and your PS3, I would highly recommend that you calibrate your set with a Blu-Ray calibration disc that comes with color filters. It will take you about an hour or so to get the hang of and use correctly but the results will be very noticeable. The presets that come out of the box and the settings that they use on the floor in the store are awful and you don't realize how much you've been missing in picture quality until you calibrate. Do not rent this disc from Netflix as it does not come eith the color filters. You can buy a calibration disc at Amazon. I got the DVE one, from what I understand, the Spears and Munsel one is very good as well.
http://www.amazon.com/s/ref=nb_sb_ss_i_0_24?url=search-alias%3Daps&field-keywords=blu-ray+calibration+disc&sprefix=blu-ray+calibration+disc
Apr 23, 2011 | Video Game Consoles & Games
Vizio L15 Television Logo
29 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
