Question about KDS Valiant 6380iPTD-01 Notebook
Need to slow down flow on valiant bolier i think its a turbomax
I have a quick question I hope.. I have just had a new shower system fitted (not electric) the control value in the shower room has a thermostat on it. My problem is that the water is going hot and cold but if I turn don the flow of the water coming out of the shower water then stays hot.
I spoke to the shower company Grohe and they asked me to do a test which was to slow down the amount of water coming out of the shower head, I did this by turning down the amount of water coming out of the shower head this then gave us a constant flow of hot water.
Can you tell me where I can turn down the flow of water to the shower form the boiler?
I have valiant turbo max
Thanks
Theres only a low flow of water coming out of the shower.
remove the head and make sure you have a good flow to the head if you do look to see if a plug needed to be removed before installation if their isn't return the product
Jul 06, 2012 | Home
On new Moen shower faucet, when I turn on faucet, water drips from shower also.
The faucet was installed upside down.
The shower riser pipe in the wall is to short( the distance between the faucet and shower head).
One of the biggest problems is if your shower faucet was installed with Pex pipe to the tub spout. Pex pipe will restrict the flow and force the water back up and out of the shower head.
The tub spout must be piped with at least 1/2 brass pipe nipples and fittings, or 5/8 OD. copper pipe and fittings.
Hope this helps, if you further questions please let us know.
Sep 08, 2010 | Moen 3175 Legend One Handle Shower Faucet...
Shower water pressure is dismal at best, girls cannot get soap out of hair, is there a way to adjust amount of water coming out of shower head, we have a delta monitor single valve assembly.
Yes, try changing the shower head and do not get one of those water saver heads...and even if you get a regular one take out the flow restrictor before installing it if it has one....it will be just inside the thread part and wil be a plastic or rubber piece with a small hole in it to slow down the water flow...
heatman101
Sep 08, 2010 | Delta & Single Handle Shower Faucet
Ive just had a new valiant 28 pro boiler
the faster the flow the low the temp , the slower the flow the hotter the temp
Feb 06, 2010 | Heating & Cooling
Vaillant turbomax 28 constant hot water problem.
got your fix, its a calcium buildup in the heat exchanger, and more than likely the rest of the unit, you will need to flush the unit with about 4 gallons of vinegar, you will need to recirculate it for about 20 mins through the unit, then flush with clean water, hook it back up, it might take a couple of mins for it to run properly, but it will, I have had the same problem with Rinnai on demand hot water systems, and it worked like a charm, check the filter thats inline as well, make sure it isnt plugged, clean if needed, also if you dont have a soft water system inplace, you might want to think about buying one and having it installed, that will reduce this from happening again for alot longer period of time, hope that helps
Jan 20, 2009 | Water Heaters
Heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Dec 15, 2008 | Water Heaters
Boiler not igniting
sorry, i think u have this in teh wrong category, it was filed under a laptop model called Valiant
Nov 23, 2008 | KDS Valiant 6380iPTD-01 Notebook
KDS Valiant 6380iPTD-01 Notebook Logo
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
