Epson printer problem
Trying to print from new MAC and only partial printing of page. Error 32 occurs "remote host did not accept data file"
smunteanu
  • 43 Answers
SOURCE: Printer only prints partial page
The carousel central axel has been twisted.
Posted on Mar 18, 2008
SOURCE: Panasonic DP 1520P - wont print
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
Posted on Nov 12, 2008
SOURCE: Error: Printing data is inaccurate, printing processing is stopped
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Posted on Dec 05, 2008
SOURCE: the epson printer driver dealing with cd printing is not installed
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Posted on Dec 06, 2008
SOURCE: Printer prints partial page and then stops
We have had the same problem. I have found that if I close all windows not being used on the computer, then try to print the document again the entire document prints. This happens on an older computer we have that doesn't have alot of RAM.
Posted on Dec 28, 2008
Error code 32 21
Code 32 errors are nearly always caused by driver problems. Whether it is a misconfigured driver, a missing driver, or a corrupt driver, it is rather safe to assume that the problem is driver-related.
You need to most likely remove, then re-install the printer driver on your machine.
Good Luck!
Rich Lilja
Apr 03, 2014 | Epson Office Equipment & Supplies
Is there a maximum file size the r800 will print.
r click on printer go to preferences select second tab PAGE SETUP go to bottom and see OPTIONS and see if the printer data size spooler is ticked
this controls the amount of data sucked up into memory in any run. so printer will pause to take the next bytes of data to print.Instead of all the data in one hit
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Epson Stylus Photo R800 InkJet Printer
Not so much a problem but got message printed out while trying to print a document. Unsupported Personality: UNKNOWN. Does this mean something I should be concerned with ??
An error page will print with the words "Unsupported Personality: PCL " in the upper left hand corner. The printers are host-based and do not support PCL printing; therefore, installing an alternate PCL5e or PCL6 printer driver will frequently generate this error condition. NOTE: This error condition occurs by design when an attempt to print with a PCL5e or PCL6 printer driver occurs and is NOT a bug within the product software. SOLUTION: Install the correct HP LaserJet Host-Based Printer Driver or the HP LaserJet printing system software for the product. These drivers are available for download from the HP web site. Click here to go to the HP web site drivers and downloads page. NOTE: There are several programs (such as accounting, invoicing, court documentation applications) that are 16 bit (DOS) programs with a 32 bit (Windows) overlay. Due to the nature of these applications and the associated Windows overlay, the errors may continue with the correct printer drivers. These applications do not typically support a host-based output device, and as such would not be supported in these environments.
Feb 24, 2010 | HP LaserJet M1522n MultiFunction Printer
Epson t88iv error codes 32
Did you set it up using Epson's receipt printer drivers? If so, right click on it and choose properties. Under the PORT tab, check and make sure it is set for proper port (LPT1, COM1, USB, etc). If you make changes, click APPLY, then OK. Then Right click, PROPERTIES, Print test Page. If you can't get test page to print, your wasting your time sending codes to printer.
Let me know if you need more assistance.
Aug 31, 2009 | Epson TM-T88IV Thermal Printer -...
Communication problem with printer over Airport, i.e. won't print
try uninstalling & reinstaling the printer will only work...
Apr 25, 2009 | Office Equipment & Supplies
I'm trying to enlarge a scanned photo, then print it on my Epson
Hi, scan at around 350dpi, save the image file as a jped and then import it into word or other program that will accept jpegs and you can make the image as big as you want up to A4 or letter size (depending on the paper size you use
Jan 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Printer error halfway through printing
This can happen if the data stream to the printer gets interrupted.  Is it always happening at the same spot, and for all files?  Maybe it could be a bad USB cable.
Jan 09, 2008 | Epson Stylus CX4800 All-In-One InkJet...
236 people viewed this question
jasbo
jasbo
