Question about BenQ PB6110 Multimedia Projector
Benq projector power on and then off - BenQ PB6110 Multimedia Projector
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
My benq MP 512 shuts down after a few minutes of use. when it shuts down all 3 light indicators are off, fan also goes off.
DONT WORRY THIS IS A REGULAR PROBLAM OF BENQ ,DELL,INFOCUS PROJECTORS UR MAIN POWER SENDER IC IS DAMEGED THROUGH UR PROJECTOR AND BUY EPSON,HITACHI,SANYO PROJECTORS
Mar 12, 2012 | BenQ MP512 SVGA 2200 ANSI 25001 22KG...
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
How can I connect BENQ MP510 multimedia projector with Acer Aspire one D255E notebook using windows 7? Do I need installation of extra driver for that?
Hi!
No you don't need a driver, connect it using a VGA Cable, then press FN Key at the same time with Fkeys that has a monitor screen Icon on your keyboard.
Hope this helps.
Mar 17, 2011 | BenQ MP510 DLP Projector
My problem is the MP721 Benq projector shutsdown immediately after it's tunred on...is there a power supply problem? How do I remedy this issue? Will the projector need to be entirely replaced, or can the...
You're right about the power supply issue, when they become faulty they are unable to supply the proper power to the projector, and thus it randomly shuts off. Also, you are able to just replace the power supply unit, I would suggest looking on ebay or contact Benq directly for a proper replacement part.
-David.
Nov 05, 2010 | BenQ Office Equipment & Supplies
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Nov 05, 2008 | BenQ PB6200 Multimedia Projector
BenQ PB6110 Multimedia Projector Logo
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
